QN9090 persistent storage options
Search instead for
Hi All,
I wonder what are the best options to have persistent storage for QN9090.
As there is no EEPROM, the only way is using one or a few of the FLASH sectors.
I can't find any sample code for data storage.
Or .. Should I use external EEPROM?
Mike
Hi MikeCalm,
   About the internal flash operation, we have the SDK which contains the flash_demo, that project will help you to finish the flash program, erase, read operation.
   You can download the SDK code from this link:
https://mcuxpresso.nxp.com/en
  Choose board as QN9090DK6 , and download SDK_2.6.1_QN9090DK6.
  You can find the flash code in folder:
SDK_2.6.1_QN9090DK6\boards\qn9090dk6\driver_examples\flash
    But, as you know , the on chip flash has the endurance limit:
If your eeprom data is write frequently, I suggest you to use the external EEPROM with I2C interface.
Wish it helps you!
If you still have questions about it, please kindly let me know!
Kerry
Hi Kerry,
Many thanks. Everything works as expected.
Mike
Hi MikeCalm,
Wish it helps you!
Kerry
