The QN9090 datasheet says
* Unique 7 byte serial number (cascade level 2 according to ISO/IEC 14443-3)
How can I read that value from my program as I need to give my product a unique serial number and may as well leverage this value.
I thank you in advance and look forward to hearing from you.
Kind regards
Mahendra
Hello Mahendra,
Hope you are doing well. The Unique 7 byte serial number is from the internal NTAG I2C of QN9090T/QN9030T.
For more information about the NFC tag, you can refer to section 42 of the QN9090(T)/QN9030(T) User Manual (UM11141). And also you can refer to the NTAG I2C Plus Data Sheet.
Hope this helps.
Ricardo
