Is there an example for BLE observer example in "BLE Host stack QN9080DK MCUXpresso SDK 2.2.0", which scans/lists for beacons?
I only found beacon broadcaster example.
Solved! Go to Solution.
Hi Arpad,
Please look at the Temperature Collector example. It connects with the temperature sensor and is using the BLE Scanner.
Also, look at the next community post. https://community.nxp.com/docs/DOC-341402
Hope it helps and let me know if you have more questions.
Mario
Hi Arpad,
Mario
