Looking at the PNEV5190 BOM, I can only see "AgilePN". How can I get actual part numbers?
Particularly, I need to know the manufacturer's PN corresponding to AgilePN 180-78936 used on PNEV5190MB.
Solved! Go to Solution.
. 1 | CADPart | 180-78936 | IND PWR 160nH@100MHZ 930mA 2% 0805 | 2 | L1, L3 |
Replacement | LQW2BANR16G00L | MURATA |
Sorry, but still not a full BOM. I found the BOM for the Module board inside the pdf, but not for the base board.
Hi Vicente,
Full BOM file with comercial part numbers of all componentes inside the board is required as reference for our design.
Can you please procide such a file?
Regards, Ramon.
on the next link, you can download several documents
https://www.nxp.com/webapp/Download?colCode=SW6594&appType=license
please check this one
TRD-X-PNEV5190M_B
regards
I can not find any solution. There is no full BOM anywhere, right?
HI,
Same problem here with several components.
Can you please provide a BOM with part numbers accessible to us. I can not find AgilePN anywhere.
Regards, Ramon.
