Hello Community,
I am working on the PNEV7462C board.
I am using the MCUXpresso IDE & running the PN7462AU_ex_phExMain example code.
As I started debugging the application, the reader data will be printed in the console of IDE.
I would like to change the interface from console to USB.
Will you please help me to know,
What is the configuration required to access the data over USB?
Shiv Patil.
Could you please help me check the following documents?
PN7462 family Software User Manual (The HIF example)
PN7462AU PC CCID Reader User Manual
I believe that you will find the documents helpful for your needs.
regards,
Estephania
