NTAG213
NTAG213
Jun8
Does anyone have an idea, can two NFC tags(NTAG213) be connected by cable? Thank you!
diego_charles
Hi @Jun8
Could you detail further your application? Do you want to exchange information between the tags?
My first answer is that the two NTAG213's can not communicate directly between each other.
Diego.
Jun8
Sincerely thanks for your reply.
I want to build my own NFC extender, I would like to know if I connect two of these cables , will it work like the existing NFC extender? Thank you!
diego_charles
Hi @Jun8
Many thanks for your reply!
Under my knowledge,   we have not  perform tests on this kind  application,  to let you know  if it is feasible.
I hope to have your understanding.
Let me know if you have any other questions.
Diego.
