NCJ29D5 INT_N pin is usually active low. I do not get any interrupt when it wakes up.
Hello
I'm sorry for the inconvenience this might cause you, but as the information of the NCJ29D5 is under NDA (Non-Disclosure Agreement) the information of it it's not public, and I'm not able to check and verify as I do not have the information due to the security levels when working with an automotive part such as this.
Could you please contact your local distributor for assistance with this device?
Jose
