[MCUXpresso] how to find labtool from SDK for using IW416, 8987 etc... with RT1060 series
bk_kim
Dear Support Team,
i am using NXP MCUXpresso v11.6.0 with RT1060 EVK + u-blox LILY-W1/JODY-W263/MAYA-W1. In the sdk, there are several example code.
For RF Certificate as like Labtool, how can I use example code for replacement of Labtool?
the example project is candidate with wifi_test_mode and wifi_cert. but thoes examples are using normal F/W which is different MFGbrige F/W.
is there any plan for Labtool like example code based on MCUXpresso environment?
BK
Labels (3)
estephania_mart
I truly apologize for the late response, for more guidance on how to use the RF test mode in the RT platform you can check the UM11442-NXP-Wi-Fi-and-Bluetooth-Demo-Applications-for-i.MX-RT-platforms-User-Guide which includes some explanation on how the demos work. Ar eyou looking into some specific command help ?
About the second question , there are plans to have some implementation, still, we can't guarantee any delivery date for it.
I apologize for the inconvenience this might cause you.
