Good morning,
i have a problem with Drivers of LPUART and GPIO of MKW36z512vht4 Project write in C.
SDK (2.2.5) drivers and project drivers created by MCUXPRESSO cannot be aligned.
I believe that the different versions of the drivers lead to the errors reported in photos.
I would ask you kindly to give me an explanation as I cannot properly fill out the project.
I thank you for your reply.
Hello Vanny,
Unfortunately, the KW36 LPUART and GPIO are not supported yet by the config tools. If you look at the problems tab in the IDE these messages appear:
I will suggest using the example codes for the LPUART and GPIO to know how to set the module.
Alexis Andalon
Hello Alexis,
thanks a lot and I hope that, as soon as possible, they can make compatible the configuration tool also for kw36.
For now, I’ll try as you suggested.
Best reguards
Vanny Cecchinato
