Locating an iPhone with UWB
Dani_100
Can the SR150 be used to locate Apple iPhones with UWB?
The idea is to use 3-4 SR150 boards connected to a PC that will locate an iPhone.
In this case, the iPhone will respond to measurement requests form the SR150 units.
Dani Aljadeff
Ricardo_Zamora
Hope you are doing well. Are you using one these Development Kits or Modules (UWB Developer Resources)?
If that is the case you would need to redirect your questions to the Module Maker, also it is good to go with them to know the process and the support that they can provide you.
I apologize for the inconveniences this might cause you.
Ricardo
Ricardo_Zamora
Ricardo
Dani_100
Thanks Ricardo!
