I found information, that KW41Z support concurrent operation of wireless comunication.
Is there documentation on how to do this?
In MCUexpresso middleware selection does not work when I create project (middleware section is empty, SDK have included all stacks).
So I should takeoff stak from SDK manualy and them run it in MSUexpresso project?
Hi Adrian, I hope you're doing well!
Are you referring to Wireless Protocol Coexistence? If this is the case, the SDK examples offers example projects showing hybrid operation of the BLE and either ZigBee, 802.15.4 or Thread Stacks.
These example and base projects can be found in the following folder of the SDK package:
<…\SDK_SDK_2.2.1_FRDM-KW41Z\boards\frdmkw41z\wireless_examples\hybrid>
Please let me know if that's not what you meant, or if you need any more information.
Sebastian
