KW41Z_31Z_21Z Design In checklist questions
Search instead for
isaotakashima
I started draw schematic for our product using KW31Z refer KW41Z/31Z/21Z Design in check-list(REV 1) at below lonk.
https://www.nxp.com/downloads/en/software-support/KW41Z_31Z_21Z_Design_In_checklist.xlsx
I cannot understand the below check item.
6.3 Have the 3pF bypass capacitors been added to PTC1-5?
Why PTC1-5 require 3 pF bypass capacitors?
Please reply as soon as possible.
Takashima
estephania_mart
Could you please refer to the AN5377 Hardware Design Considerations for MKW41Z/31Z/21Z BLE and IEEE 802.15.4 Device section 6.1.1 for further information about this?
Estephania
isaotakashima
Dear Estephania
Thank you for your reply.
I want to use PTC2 and PTC3 with LPUART0_RX and LPUART0_TX respectively.
Is the 3 pF bypass capacitor necessary also in this case?
Takashima
estephania_mart
Those capacitors are needed also in that case, in the PORTC in general, this is in order to reduce some peaks and be able to pass the certifications.
Estephania
