KW36 required: RSA 1024 algorithm library support
Search instead for
The current nxp sdk of kw36 does not support RSA 1024 encryption/decryption algorithm.
Will nxp be able to add RSA-1024 code in our framework in the nxp sdk we have?
Sai Kalyana Raman
Labels (3)
Hello Sai Kalyana,
As you mention de current stack doesn't support the RSA encryption so I will suggest to use the mbedLTS library for this.
In the SDK from the FRDM-KW41 this library is already integrated so could check the example frdmkw41z_demo_apps_mbedtls_mbedtls_benchmark, copy the folder mbedtls and update the paths of your project.
I hope this helps you.
Alexis Andalon
