KW36 : Pairing getting failed sometimes in huawei P8
Search instead for
I try to pair Huawei P8 with KW36.
I have imported hid device example with security mode 1 and level 2.
I use just works pairing.
Sometimes i see pairing is getting failed , can you please let me know why the pairing is getting failed from the attached airtrace.
Please find the attachment for the airtrace.
Sai Kalyana Raman
Labels (3)
Hi Sai, I hope you're doing well!
Could you please let me know how is your application getting configured? Did you change anything else apart from the security mode and level? Which SDK version and IOT Toolbox Application are you using?
Also, could you please let me know if you're using NVM?
Does this only happen with your Huawei P8?
Sebastian
