The documents on the NXP website do not provide WIFI Co-existence related documents(Pin settings, software timing diagram).
Is NXP currently ready for this function(WIFI Co-existence)?
If so, can it be released?
Thank you for your support, we will find other solutions by ourselves
Hi Daniel,
Please let us know if you need any more information.
Take care, best regards,
Sebastian
Hi Sebastian,
Customer only provides three pins, no more information.
What we want to know is whether K32W currently supports Co-existence function?
If not, when will the Co-existence SDK be released ?
In addition, is it possible to know first, which three pins correspond to the K32W pins?
This is the first thing we want to know.
Hi Daniel, I hope you're doing well!
This matter was handled internally.
Sebastian
We use IPQ807x as Wi-Fi module.
WIFI Co-existence has the following three pins:
PTA2_0 = PTA_RE(Input)
PTA2_1 = PTA_PRIORITY(Input)
PTA2_2 = PTA_GRANT(Output)
I don’t know the corresponding pin of Co-existence of K32W, and I don’t see any related software support.
Hi Daniel,
Could you please provide some more information about the application being developed?
Mainly, could you please let me know which Wireless Communication Protocol Stacks are being used for this application?
Are you using any SDK Example?
Sebastian
Could you please provide some more information about the Wi-Fi module or device is being connected to the K32W in your system?
Sebastian
