K32W ISP for LPC-LINK2
Search instead for
Contributor V
Refer to "ch 2.5.2 ISP button" of UM11393
DK6 Production Flash programmer can be executed on FTDI USB interface.
Can the DK6 Production Flash programmer be executed on LPC-Link2?
  • KW
Contributor V
Since I got JN-UN-3127, I have understood.
It is good that the document helped you.
Estephania
Hello,.
Could you please check the DK6 Production Flash Programmer User Guide ? you will need to check the chapter 1.4 Loading Application Binary File into Flash Memory
Estephania
