Please follow the document to install the tool chain.
https://www.nxp.com/docs/en/nxp/user-guides/UM11356.pdf
Notice the page 4.
TIC
- We are following threads for 7 days after the last post, later replies are ignored
Hi @nxf56274 ,
I have downloaded these tools before, and used SDK2.6.2_JN5189 version of SDK for development. The phenomenon after compiling and downloading the program is normal, but when switching to SDK2.6.0_JN5189SDK, the compilation is not normal. Now I have downloaded these tools again, but the problem is still not solved, may I ask what may be the cause?
BR,
Viki
You should notice the console output. Check if it handle the bin file normally. The IDE generate the bin file, and then it will call the python script to encrypt the bin file. If this operation doesn't operate correctly, the bin file can't be used. It's not the IDE problem, but your tool chains' problem.
TIC
