JN5189 RSSI and LQI
Search instead for
JN5189 RSSI and LQI
sean2sean
Hi. I am developing Zigbee application using JN5189 and DK6. I couldn't find a function to read the RSSI and LQI. How can I check the RSSI and LQI? Please let me know if there is a register or API that can check the value.
mario_castaneda
Hi @sean2sean,
I hope you are doing great.
Please look at the JN-AN-1255 Example. It implements the read-out LQI and RSSI Values.
  uint32 u32Rssi = u32REG_RFPModemRead(MF_RSSI_DBM_PACKET);
  int32 i32Rssi = ((int32)(u32Rssi << 22)) >> 22;
  i32Rssi = abs(i32Rssi);
  uint8 u8Lqi= u8MMAC_GetRxLqi(NULL);
Mario
