JN517x lock mutex/ enter critical sections
Search instead for
jurijhuebner
are there any applications/ code samples to use the following functions:
-     OS_eEnterCriticalSection()
-     OS_eExitCriticalSection()
-     ZPS_u8ReleaseMutexLock()
-     ZPS_u8GrabMutexLock()
I am working on the OTA and as I read, the functions above are important for using OTA. But I did not found any application note where OTA is using this functions? Could you help me?
Jurij
mario_castaneda
Hi Jurij,
There is no OTA example using this functions, I am looking with the APP team an example with this functions.
Mario
mario_castaneda
Hi Jurij,
Are yo trying to implement OTA?
What is the example that you want to use with the OTA process?
Mario
jurijhuebner
Hello Mario,
we started with the application Light Bulb. With no success, but now we switch to Controller and Switch and it seems to run better. We are still testing.
Jurij
