While testing with the JN516x-EK004 Evaluation Kit, I have managed to over-write the original factory image on the ESP-EM dongle. Where can I get a copy off these images? Better yet, where is the source code for these images?
Hi Sean,
The code example that we provide with the evaluation boards are the same that we provide on our web pasge.
USB Dongle: JN-AN-1223 Iot Gateway
Carrier boards: JN-AN-1189 ZigBee Home Automation Demonstration Application Note
However, you could look at the Zigbee 3.0
Mario
