Hi all
I am reading a value from a potentiometer through one of the ADC channels on the JN5169 for testing purposes. The potentiometer will be replaced with a sensor when i have the program doing what i need to do with it. I am wanting to packet this value up and be able to read it from the coordinator which in turn will save this to a MySQL DB.
I am struggling on finding where to place my code. I am using the JN-AN-1229-ZigbeePro-Application-Template files.
Any help is much appreciated.
regards
Matthew
Hi Matthew, I hope you're doing well!
To get an idea of how to implement a sensor or a voltage measurement, you could check the JN-AN-1220 Sensors application note. It shows the creation of the clusters and endpoints required, as well as the implementation of the report to send the information to a coordinator.
This example shows a few different implementations, so it should be helpful to get an idea.
Zigbee 3.0 Application Note software.
Please let me know if you have any further questions.
Sebastian
