I am running the project JN-AN-1069,in the uart.c file,(I have changed some code)code as :
it can print UART_OPEN 4,but it can‘t print UART_OPEN 5 ,I think I'm stuck in the function vAHI_UartSetInterrupt(),
when I try to find this funtion , I only find a declaration in a .h file, so How Can I Solve This Problem? I mean how to make me don't stuck in this function anymore?
Hi Zhenyu,
Did you define the JenOS as TRUE?
Why do you comment the code?
#define UART_JENOS FALSE /**< Compile for JenOs */
Mario
