I can't find specific information.
Is it possible to acquire payload data by sniffing connection using USB-KW41Z?
Can I sniff whole connection or only part on advertisement channels?
Also can anyone give me example file with wireshark connection dump? Iit will be great to check that file before buying sniffer to examine it functionalites.
Piotr
I replied to you in the internal case,
Estephania
Thank you very much. I replied you with one more question.
If there is no problem I think you should put answer and file here that anyone can get access to it.
I'll check it out, I already posted it in another thread that's why I did not put it here again.
Estephania
Where I could find your post in another thread ?
