IW612, 88W8997 and 88W9098 power consumption
YukioOyama
How many is the power consumption of IW612, 88W8997 and 88W9098?
Please tell me along with the measurement conditions. Where can I get the datasheet with them?
Yukio Oyama
estephania_mart
Hello ,
Most of the documentation of the parts is under NDA.
For the 88w8997 and the 88W9098 you can request access through the NXP chat and they can guide you through the process and you can also request higher access in your available secure files .
You will need to enter the part documentation, select secure files and after that you will see a "Request Higher Access"
For the IW612, as the device has not been released yet ,could you please contact one of our distributors available in the Distributor Network|NXP to help you with your request?
estephania_mart
Hello ,
YukioOyama
I saw that tag. And I've been through that process.
But there is no Wi-Fi in wireless connectivity. What in which category should I choose?
I don't have an NDA with you, but how long does this process take?
Yukio Oyama
estephania_mart
It would be en each part number, for example in the 88W8997 you go to the Design Resources tab
After that you go to the Documentation section and there you can find the Secure Files
You need to repeat this process for each of the parts
About the time , I apologize I can't provide a specific time as it depends on the process of each customer, please reach out to the Live Chat for more details on this
YukioOyama
In my last question, I did not indicate all the preconditions.
I understand that the "Secure Files" radio button switches to Secure Files.
However, I do not yet have "Secure Access Rights".
So I am trying to apply for it.
I will proceed to answer a few questions for that right, but I don't see "Wi-Fi" in the "Wireless Connectivity" category - which category should I select to see the secure file for the Wi-Fi module? (<-This part was what I wanted to ask in last conversation)
This question may be outside your work, but unfortunately, the Live Chat is always offline when I view it.
Yukio Oyama
estephania_mart
Please help me following the process sent directly
YukioOyama
I have received an email from NXP to proceed with that process. Thanks for your support, it's been a great help.
I hope my question will be resolved when I see the secure file.
I close this case here. Thank you.
Yukio Oyama
