How to store network data between resets
alexstefan
Is it possible to store network data (PANID, channel, node information for coordinator, short address, PANID, channel for end devices) and allow the devices to resume communication after a network reset?
Thanks!
Labels (2)
estephania_mart
Which protocol are you using ? Is it ZigBee? Thread? 802.15.4?
Estephania
alexstefan
Thanks!
estephania_mart
You can try using the NVM_Interface APIs in your debug, could you please check them an verify if those are helpful for you ?
Estephania
alexstefan
Sorry, maybe I wasn't clear with my question. The problem is not storing the data between resets, but how to use the stored data to resume connection from the end device to the coordinator, without scanning for available networks again and going through the association process.
Thanks!
