How to receive a multicast POST message from Thread nodes to my Linux+TAP machine
Search instead for
diegocomin
Hi all,
I followed this tutorial Thread Border Router using Linux + KW as Host Controlled Device with Serial TAP for DHCPv6-PD  to create a complete Border Router with my Raspberry PI + Host Controlled Device with Serial TAP.
At this point I am perfectly able to communicate to my nodes when I make coap messages from my RP. However, I want to receive the multicast POST message that my Thread nodes send.
When I make a multicast POST request from a node, I am able to see the message sent in every node from my Thread network, but I am not able to see it from the Thread_Shell program of my host controlled device + RP with TAP.
There is any way to obtain the multicast POST message in my Border Router configured with serial TAP?
Diego C.
Labels (3)
diegocomin
Hi Alexandru,
I have already solved the issue. The RP had the fd01::2 Ipv6 so I created a task in the KW41Z to send a Coap message to this IPv6 address. In order to receive the coap message in the RP I set up a CoAP Server in python attached to the Ipv6 address fd01::2.
Thanks I apreciate so much your concern!
Diego Comin
diegocomin
Hello Alexandru,
Have you found any solution to my issue?
Diego C.
Alexandru-Lilia
Hello Diego,
At this moment I don't have the hardware to do the setup yet, I will get to you as soon as I have it set up and figured out.
Lilian
Alexandru-Lilia
You are probably receiving the CoAP message, but it doesn't appears on the shell. To make sure, you can check with a sniffer if you get ACK from the said device.
Lilian
diegocomin
Ok surely I receive the CoAP message to my Host Controlled Device (the R41Z module), but how can I receive the message from my Raspberry Pi connected with serial TAP to the Host Controlled Device?
Alexandru-Lilia
Hi Diego,
It would help me if you make a Wireshark capture when you send the messages. You need an wireless sniffer, or fi you don't have one, can you make a capture on the Thread interface from raspi?
Lilian
diegocomin
Hi Alexandru,
Diego Comin
