How to know the NwkAddr of EndDevice
Search instead for
When the EndDevice leave zigbbee network,the Coordinator could know the u64ExtAddr of enddevice,but how to know its u16NwkAddr?
Labels (3)
How are you removing the ED from the ZigBee Network? Is there any specific reason that you want the short address?
Remember when the end device sends the leave command this address had been erased from the table.
Please look at the API uint16 ZPS_u16AplZdoLookupAddr(uint64 u64ExtAddr)
Document ZigBee 3.0 Stack User Guide
Mario
Yes, the problem has been solved according to your suggestion,thank you.
