GAPConnect is not giving any response
devangdixit
I have modify the hrs.py script present in kw41z sdk to work as a central application.
But I am not able to connect to the scanned device(ipv6 node which is advertising at an interval of 20 ) using GAPConnect.
I am not able to get any response from the black box.
estephania_mart
could you please let me know which example are you basing on ?
Estephania
