Firmware for uBlox JODY-W2 to work with i.mxrt1050/i.mxrt1060
977件の閲覧回数
EngHuiPeng
Customer is looking for the firmware to test this module with i.mxrt1050. Communicated with i.mxrt1050 and tried the firmware used for Azureware CM358(using 88W8987)
 https://community.nxp.com/t5/RT-4-Digit-10xx-11xx-12xx/i-mxrt1050-SDK-for-Wifi-module-uBlox-JODY-W26...
Customer is seeing error as posted in the link. Would like to know whether there is any firmware to test this uBlox Jody -W2 module with i.mxrt family. If not, when it expect to be release in the SDK so  that customer could do the testing.
Thanks.
Audrey
3 返答(返信)
965件の閲覧回数
estephania_mart
You can check this getting started,
https://www.nxp.com/document/guide/getting-started-with-nxp-wi-fi-modules-using-i-mx-rt-platform:GS-...
I would recommend you to check the latest SDK with the support for the modules mentioned in the getting started guide.
Estephania
958件の閲覧回数
EngHuiPeng
Hello Estephania,
Thanks for the link. Customer already following the step as in the video.
Customer is using the latest SDK 2.10.0 for IMXRT1060 eVK board as the 8987 chipset was enabled only in 1060 examples
 Pls see the error on this link:
Audrey
948件の閲覧回数
estephania_mart
I sent you a direct message, could you please help me check it ?
Estephania
