Facing a Problem in JN-AN-1184-ZBPro-Application-Template
davidashraf
Contributor V
I am trying JN-AN-1184-ZBPro-Application-Template on JN5168-001-M00 module but the sleeping end device node seems to have a problem in joining.
Here's a screenshot of the debug messages coming from SED node
The debug messages coming from Coordinator node!
Any ideas to solve this ?
Thanks in advance.
arthurpulatov
Have the same problem, are you still try to solve that  or it's already fixed?
davidashraf
Contributor V
Never managed to solve it unfortunately
dmsherazi
Hi davidashraf did you manage to solve it as of now? I am having the same issue and I desperatly need to get through. Unfortunately support from NXP dosent respond to many questions
davidashraf
Contributor V
I still need the answer to this , anyone can help  ?
