Do you have any similar command to “LE Set Host Channel Classification Command” in FSCI so that we can map the data channel based on the WiFi operating band? josmannmichaelgoudeykoonlee kajac
I am sorry for the inconvenience this may cause you, but the functionality you are looking for is not supported through the FSCI or the stack.
Estephania
