I'm a JN5148 user, and recently I was facing re-install the "JN5148 Software Developer’s Kit" by following the instruction from "JN-UG-3064-JN5148-SDK-2v0.pdf", everything went right except when I was trying to "Installing the Configuration Editors (ZigBee PRO)" (on page33), the update site you provide (http://eclipse.jennic.com/update-site) is no longer available. I can't do any further work associated with ZigBee PRO until this problem is fixed. Anybody know any solution for this? I really appreciate that!
I'm also interrested by the new link to have access to the site http://eclipse.jennic.com/update-site. I would like to change my ZigBee configuration. Without this link I can't modify my zpscfg file with this Eclipse plugin.
Thanks.
I did it !
This instructions work for me:
To install tools for build project into BeyondStudio for JN5148, you should have an old installer. In the c:\Jennic (installation directory default of the old sdk), copy the folder Chip, cygwin, Components, Platform, into the install directory C:\NXP\bstudio_nxp ; Modify the file Jennic_Cygwin.bat located into the cygwin folder (C:\NXP\bstudio_nxp\cygwin).
Import an old project into Beyond Studio, right clic on the project->properties. In C/C++ Build-> environment, set the CYGWIN_HOME with C:\NXP\bstudio_nxp\cygwin
Remove all the file in the build folders EXEPT the makefile.
Left clic on the hammer to build your project and you will see some mistake. You have to copy into the C:\NXP\bstudio_nxp\Tools some old tools located in c:\Jennic\Tools. To know which one, you have to look at the compilation errors in the console windows. For my project, I have to copy OVLYUtils, OSconfig, ba-elf-ba2, PDUMConfig, ZPSCONFIG
