Dose W8997 supports the SDIO 3.0 CMD11 to switch from 3.3V signaling to 1.8V signaling?
if yes, in sdio3.0 mode, Is it mandatory to supply 1.8v to W8997 VDDIO? or i can select supply 3.3v to W8997 VDDIO in sdio3.0 mode?
Solved! Go to Solution.
Dear @changbaoma ,
Let me join the disscussion.
No, it doesn't.
SDIO card doesn't support switch IO voltage, but SD card(mem card) supports it.
For your hardware design:
--Host side
Host SDIO interface should be applied 1.8V IO if you want to use SDIO 3.0.
--WiFi chip side
(1) VIO_SD should be supplied 1.8V.
VIO_SD is only for SDIO signals
(2) VDDIO
VDDIO is for the levle of other signals.
yes, you can.
VDDIO determines IO voltage, like PCM/UART/other single-end signals lines except for SDIO lines
Hope above infromation is helpful for you.
Have a good day!
weidong
Dear @changbaoma ,
No, it doesn't.
--Host side
--WiFi chip side
(2) VDDIO
yes, you can.
Have a good day!
weidong
Please help me check the Datasheet of the device in chapter 9 Electrical Specifications. I believe that you can find more details on your request there
Estephania
Hello, @estephania_mart
Can you show me the link of W8997 datasheet. I can't find it in NXP site.
