Determine reset reason of a JN516x?
Search instead for
augustbering
Is there any way I can detect if a restart of JN516x was because of the NRESET pin being pulled or because the power was turned off and on again (and I don't mean a brownout reset.) ?
estephania_mart
Could you please check the DataSheet of the JN5169  chapter 9? I believe that specially the section  9.4.4 Supply Voltage Monitor (SVM) will be helpful for you.
Estephania
