Default Response on JN5169
nguyenanhgiau10
Hi all,
I facing a problem: My coordinator not receive Default Response from any device when I send a command.
I defined:
/* Set this True to disable non error default responses from clusters */
#define ZCL_DISABLE_DEFAULT_RESPONSES (FALSE)
#define ZCL_DISABLE_APS_ACK (FALSE)
How can I resolve it?
  • JN
mario_castaneda
Hi Gia,
Could you please modify the structure directly? zcl.c file.
    psZCL_Common->eLastZpsError = ZPS_E_SUCCESS;
    psZCL_Common->bTimeHasBeenSynchronised = FALSE;
    psZCL_Common->eSecuritySupported = E_ZCL_SECURITY_NETWORK;
    psZCL_Common->bDisableAPSACK = FALSE;
Please let me know your findings.
Mario
nguyenanhgiau10
Hi Mario,
I just get Default Response in several time. After that, I don't get it more.
Do I need to modify source code on other device?
mario_castaneda
Hi Giau,
Could you please check the frame control field, and what is the value of the bit 4?
Could you please provide the sniffer log?
Mario
