Hi all,
I facing a problem: My coordinator not receive Default Response from any device when I send a command.
I defined:
/* Set this True to disable non error default responses from clusters */
#define ZCL_DISABLE_DEFAULT_RESPONSES (FALSE)
#define ZCL_DISABLE_APS_ACK (FALSE)
How can I resolve it?
Hi Gia,
Could you please modify the structure directly? zcl.c file.
psZCL_Common->eLastZpsError = ZPS_E_SUCCESS;
psZCL_Common->bTimeHasBeenSynchronised = FALSE;
psZCL_Common->eSecuritySupported = E_ZCL_SECURITY_NETWORK;
psZCL_Common->bDisableAPSACK = FALSE;
Please let me know your findings.
Mario
Hi Mario,
I just get Default Response in several time. After that, I don't get it more.
Do I need to modify source code on other device?
Hi Giau,
Could you please check the frame control field, and what is the value of the bit 4?
Could you please provide the sniffer log?
Mario
