I just created the app_led.c and app_led.h files and define a function under the new folder, then called the function in app_main.c. This will cause a compilation error.
BUT, if I define the same function under the existing folder (app_end_device_node.c), then called the function in app_main.c. This will be no error.
Is this because the .c.h file I created requires additional system configuration?
Please give me some accurate advice, I have spent too much time to solve this problem, thank you very much.
Hi Zhang,
You have to modify the makefile
#APPSRC += app_exceptions.c
APPSRC += app_start.c
APPSRC += app_end_device_node.c
APPSRC += app_zcl_task.c
APPSRC += app_buttons.c
APPSRC += app_led.c
Mario
Hi Mario,
it's OK now.
Thank you very much for taking the precious time to help me solve the problem.
Zhang
