Changing Tx power of BLE
Search instead for
sensenthuran
We could change the tx power during the compile time by changing mAdvertisingDefaultTxPower_c. Once compiled, the Tx power is fixed.
Is there any FSCI API for changing the TX power of kw40/41z  during the run time ( while bootup)?
 In “BLE Host Stack FSCI Reference Manual.pdf”
I could see TxPowerLevelRead but not Set/write.
Looking for "FSCI command" correspond to
SetTxPowerLevel (mAdvertisingDefaultTxPower_c, gAdvTxChannel_c);
mario_castaneda
During run time, we don't have an API for change the TX Power,
Txs_SetTxPowerLevel, update TX power, but you have to select the dbm that you want to send. You can't change this value in run time
Mario
sensenthuran
Sent from my BlackBerry 10 smartphone on the Koodo network.
