Can JN5169 externally expand RAM?
Search instead for
1979717461
Can JN5169 externally expand RAM? I want to confirm whether JN5169 can expand RAM.
If you know, tell me.
Thanks!
  • JN
Tags (2)
Sebastian_Del_Rio
Hi, I hope you're doing well!
Theoretically speaking, it's possible to add external RAM, because the JN5169's memory map has unassigned address blocks, but the included APIs don’t natively support external RAM. To do this, you would have to implement it yourself. Alternatively, you could try using an external flash or EEPROM memory instead of RAM.
Please let me know if you need more information.
Sebastian
