Build Connectivity Software in Linux
Search instead for
andreiemeltchen
I have downloaded and extracted KW40Z_Connectivity_Software_1.0.1. Can I build it in Linux like I can build apps in KSDK?
Labels (2)
mario_castaneda
Hi Andrei,
If you found and install IAR for Linux, it should works, but as you know the KW40z for the connectivity software only supports IAR.
Mario
