Hi, does above product support ble mesh? because datasheet do not mentioned any "ble mesh".
Solved! Go to Solution.
There are some of our radios that can support it , nonetheless, we currently do not have any software to enable BLE Mesh .
Still, you could work with a third party supplier and get a Bluetooth Mesh Stack and have it running or you could check and verify if some open source has the support for some of our parts (like the Bluetooth Mesh software that is part of Zephyr).
You can also check with the professional services in this link.
I apologize for the inconvenience this might cause you.
The current enabled features for the devices you are using can be found in this document for the Linux releases
Also, you can check the Bluetooth Controller Certification
For the 8987
• Class II - https://launchstudio.bluetooth.com/ListingDetails/11394
• Class -I - https://launchstudio.bluetooth.com/ListingDetails/24794
For the 9098
• Class II - https://launchstudio.bluetooth.com/ListingDetails/98383
• Class I - https://launchstudio.bluetooth.com/ListingDetails/97047
Thanks for information. Does any other nxp product support ble mesh(or bluetooth SIG mesh)?
Thanks!
Could you please help me with more details on which specific device are you referring to ?
Regards ,
Estephania
Thanks for reply. I am interested in 88W9098 and 88W8987, does it support bluetooth SIG mesh?
