Hello. Please tell me.
Is "CW641" currently available?
Also, can you give me the recommended antenna list information if it is available for sale?
Best Regards.
Solved! Go to Solution.
Dear customer,
I do not have inputs on such antennas.
Olivier
Hello Olivier-san
Thank you for your reply. I understand now.
Is there a list of Japanese certified antennas for 88W9098 somewhere?(WiFi)
Best Regards.
Dear customer,
Olivier
Dear customer,
We have products supporting WiFi 6 (802.11ax), like 88W9098 (see https://www.nxp.com/products/wireless/wi-fi-plus-bluetooth/2-4-5-ghz-dual-band-2x2-wi-fi-6-802-11ax-...).
But we do not have yet products supporting the 6GHz band introduced with WiFi 6E.
Olivier
Hello Olivier-san
What I would like is information on products that support WiFi6E (802.11ax).
Do you have a product that supports that?
If so, I would also like information on antenna listings.
Best Regards.
Dear customer,
CW641 chipset was cancelled, so it will never be available.
Could you please clarify your needs, so we can propose the corresponding chipset:
1/ Device type (IoT, gateway, etc)
2/ Main usage (STA/client, Access Point ?)
3/ Host used (i.MX, other)
4/ Host OS (RT, Linux, Android, etc)
5/ Wifi host HW interface (PCIe, SDIO, other)
6/ BT host HW interface (UART, other)
7/ Wifi protocol (802.11ax ?)
6/ MIMO required ?
Olivier
