Could you please help us contacting the module manufacturer for some more information about the available resources for the module ?
The device indeed supports Mesh, still, you will need to check with the module manufacturer to validate the available drivers and enablement available for the specific module
Estephania
Thank you,
The URL where the product was purchased is https://www.hd-wireless.com/
I purchased the SPB228 Evaluation board(HDA228-USB-SDIO) module here, and brief information about the product is http://docker.hd-wireless.com/Support/SPB228
If you don't log in, you can only see very limited information.
Pls, ask you to confirm about supporting Mesh..
Hello ,
Yes, I understand, that is the reason why I mentioned the chip supports that but you will need to verify with the manufacturer of your module about the enablement of those capabilities within their drivers.
Estephania
