The best way to build a PCB using a KW38 the first time right !
100% helpful (1/1)
Please, find the important link to build a PCB using a KW38 and all concerning the radio performances, low power and radio certification (CE/FCC/IC).
Your first task before to send any inquiry to NXP support is to fill the KW38 Design In CHECK LIST available in this ticket.
KW38 product NXP web page:
KW39/38/37 32-bit Bluetooth 5.0 Long-Range MCUs|NXP | NXP Semiconductors
FRDM-KW38 getting started NXP web page
Getting Started with the FRDM-KW38 | NXP Semiconductors
HW:
FRDM-KW38 User Guide: FRDM-KW38 Freedom Development Board User’s Guide (nxp.com.cn)
Hardware design consideration: Hardware Design Considerations for MKW39A/38A/37A/38Z/37Z Bluetooth LE Devices (nxp.com)
Minimum BoM: KW37_38_39 Minimum BoM Presentation.pdf - NXP Community
DCDC management guide : MKW4xZ/3xZ/3xA/2xZ DC-DC Power Management (nxp.com)
         Migration guide: KW36 to KW38: Migration Guide from MKW36A512xxx4 to MKW38A512xxx4 (nxp.com)
         Design-In check list: attached excel file
        Configuration for Unused Pins/GPIOs on Kinetis
Radio:
RF report: https://www.nxp.com.cn/docs/en/application-note/AN12517.pdf
Annex: MIIT (China) sharpened Homologation on FRDM-KW38 &... - NXP Community
         Radio co-existance: FRDM-KW38 Co-existence with RF System Evaluation Report for Bluetooth® Low Energy Application (nxp.c...
Low Power Consumption: https://www.nxp.com/docs/en/application-note/AN12459.pdf
Distance performances: KW37_38_39_Bluetooth LE Range Performance.pdf - NXP Community
Antenna: https://www.nxp.com/docs/en/application-note/AN2731.pdf
         Generic FSK Link Layer Quick Start: Connectivity test SW user guide in attached pdf file
         Binary file attached: Connectivity test frdmkw38.bin
         Return loss (S11) measurement: attached file
         Loadpull: attached file
Low Power:
         Low power estimator tool link:
https://community.nxp.com/t5/Connectivity-Support-QN-JN-KW/BLE-power-profile-calculator-v0p3-xlsx/ta...
SW tools:
         IoT Tool box
         Connectivity test tool for connectivity products
         DTM: How to use the HCI_bb on Kinetis family products a... - NXP Community
https://community.nxp.com/t5/Wireless-Connectivity-Knowledge/BLE-HCI-Application-to-set-transmitter-...
Certification:
         Zip attached file and the community link:
KW39 KW38 KW37 Radio certification documents - NXP Community
Comments
KW36 - Trimming adjust of 32MHz XTAL external oscillator
KW36 - Trimming adjust of 32MHz XTAL external osci... - NXP Community
Version history
Last update:
‎11-08-2021 06:49 AM
Updated by:
