Wireless Module Guidence: mwifiex, Firmware on PCIe Wi-Fi on Lattepanda Sigma, AlmaLinux
1,689件の閲覧回数
cvd21073
Dear NXP Tech Support Team,
i need help with enabling the Wi-Fi module on my LattePanda Sigma (Intel CPU) running AlmaLinux 10.
Wifi-Module - JODY-W377-00B
Chipset - NXP 88W9098 / 88Q9098
Are there any installation instruction regarding driver and firmware available?
Thank you in advance for you help.
Kind regards
タグ(2)
9 返答(返信)
1,662件の閲覧回数
shaun_wu
Hello @cvd21073
We provide driver and firmware download link here.
UM11675 | NXP Semiconductors
About porting driver to your platform. Intel will have a guide.
Best Regards
Shaun
1,655件の閲覧回数
cvd21073
Thanks for guidance,
But i have faced problem with starting firmware.
Please see below logs:
[16055.070437] wlan: Loading MWLAN driver
[16055.070688] wlan: Register to Bus Driver...
[16055.070761] usbcore: registered new interface driver usbxxx
[16055.071025] PCI memory map Virt0: 0000000043335f46 PCI memory map Virt2: 000000004afdb115
[16055.071042] Attach moal handle ops, card interface type: 0x206
[16055.071044] rps set to 0 from module param
[16055.071045] No module param cfg file specified
[16055.071051] rx_work=1 cpu_num=16
[16055.071053] Enable moal_recv_amsdu_packet
[16055.071059] Attach mlan adapter operations.card_type is 0x206.
[16055.074216] Request firmware: nxp/pcieuart9098_combo_v1.bin
[16055.342741] prog_fw: Failed to get command done interrupt retry count = 10001
[16058.642099] FW failed to be active in time!
[16058.642107] wlan_dnld_fw fail ret=0xffffffff
[16058.642110] WLAN: Fail download FW with nowwait: 0
[16058.642119] Config Space Registers:
[16058.642124] reg:0x00 value=0x2b431b4b
[16058.642127] reg:0x04 value=0x00100406
[16058.642130] reg:0x10 value=0x3c20000c
[16058.642133] reg:0x18 value=0x3c30000c
[16058.642136] reg:0x2c value=0x2b431b4b
[16058.642139] reg:0x3c value=0x00000105
[16058.642142] reg:0x44 value=0x00000008
[16058.642145] reg:0x80 value=0x10120143
[16058.642148] reg:0x98 value=0x00000400
[16058.642152] reg:0x170 value=0x0001001e
[16058.642156] FW Scrach Registers:
[16058.642159] reg:0x1c90 value=0xfedcba00
[16058.642162] reg:0x1c98 value=0x0
[16058.642165] reg:0x1c9c value=0x0
[16058.742176] reg:0x1c98 value=0x0
[16058.742180] reg:0x1c9c value=0x0
[16058.842186] Interface registers dump from offset 0x1c98 to 0x1c9f
[16058.842193] PCIE registers from offset 0x1c20 to 0x1c9c:
[16058.842209] 00000000 00000002 0000004f 00000000 ffffffff 00000002 00000000 00000000
[16058.842224] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[16058.842240] 2005b000 00000000 00000010 00000000 008047e3 c8701424 00000000 00000000
[16058.842256] 00000000 00000000 00000000 00000000 fedcba00 00000000 00000000 00000000
[16058.842257] ADMA Tx/Rx/Event/Cmd/CmdResp registers:
[16058.842258] ADMA registers dump from offset 0x10000 to 0x10068
[16058.842273] 00100000 1e488000 00000000 c010ad64 00000000 00000000 00000000 00000000
[16058.842289] 00000000 00000001 00000000 00000000 00000000 00000000 00000000 0000f002
[16058.842304] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000002
[16058.842310] 80000948 00000000 00808c8c
[16058.842311] ADMA registers dump from offset 0x10800 to 0x10868
[16058.842326] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[16058.842342] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 0000f000
[16058.842357] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000002
[16058.842363] 80000948 00000000 00808c8c
[16058.842364] ADMA registers dump from offset 0x10880 to 0x108e8
[16058.842379] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[16058.842395] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[16058.842410] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000002
[16058.842416] 80000948 00000000 00000000
[16058.842417] ADMA registers dump from offset 0x11000 to 0x11068
[16058.842432] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[16058.842447] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 0000f000
[16058.842463] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000002
[16058.842469] 80000948 00000000 00808c8c
[16058.842470] ADMA registers dump from offset 0x11080 to 0x110e8
[16058.842485] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[16058.842500] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[16058.842515] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000002
[16058.842522] 80000948 00000000 00000000
[16058.842680] woal_request_fw failed
[16058.842684] Firmware Init Failed
[16058.846592] Free module params
[16058.846698] woal_pcie_probe: failed
[16058.846701] wlan_pcie 0000:03:00.0: probe with driver wlan_pcie failed with error -14
[16058.846773] PCI memory map Virt0: 000000007132ef2a PCI memory map Virt2: 000000007089599c
[16058.846777] Attach moal handle ops, card interface type: 0x206
[16058.846780] rps set to 0 from module param
[16058.846781] No module param cfg file specified
[16058.846786] rx_work=1 cpu_num=16
[16058.846787] Enable moal_recv_amsdu_packet
[16058.846791] Attach mlan adapter operations.card_type is 0x206.
[16058.851016] Request firmware: nxp/pcieuart9098_combo_v1.bin
[16059.110692] prog_fw: Failed to get command done interrupt retry count = 10001
[16062.410938] FW failed to be active in time!
[16062.410943] wlan_dnld_fw fail ret=0xffffffff
[16062.410946] WLAN: Fail download FW with nowwait: 0
[16062.410955] Config Space Registers:
[16062.410959] reg:0x00 value=0x2b441b4b
[16062.410962] reg:0x04 value=0x00100406
[16062.410965] reg:0x10 value=0x3c10000c
[16062.410968] reg:0x18 value=0x6c900004
[16062.410971] reg:0x2c value=0x2b441b4b
[16062.410974] reg:0x3c value=0x00000203
[16062.410977] reg:0x44 value=0x00000008
[16062.410980] reg:0x80 value=0x10120143
[16062.410983] reg:0x98 value=0x00000000
[16062.410987] reg:0x170 value=0x0001001e
[16062.410991] FW Scrach Registers:
[16062.410994] reg:0x1c90 value=0xfedcba00
[16062.410997] reg:0x1c98 value=0x0
[16062.411000] reg:0x1c9c value=0x0
[16062.511010] reg:0x1c98 value=0x0
[16062.511014] reg:0x1c9c value=0x0
[16062.611020] Interface registers dump from offset 0x1c98 to 0x1c9f
[16062.611029] PCIE registers from offset 0x1c20 to 0x1c9c:
[16062.611045] 00000000 00000002 0000004f 00000000 ffffffff 00000002 00000000 00000000
[16062.611061] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[16062.611076] 1e8f8000 00000000 00000010 00000000 008047e3 c8701424 00000000 00000000
[16062.611092] 00000000 00000000 00000000 00000000 fedcba00 00000000 00000000 00000000
[16062.611094] ADMA Tx/Rx/Event/Cmd/CmdResp registers:
[16062.611095] ADMA registers dump from offset 0x10000 to 0x10068
[16062.611110] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[16062.611125] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 0000f000
[16062.611140] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000002
[16062.611147] 80000948 00000000 00808c8c
[16062.611148] ADMA registers dump from offset 0x10800 to 0x10868
[16062.611163] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[16062.611178] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 0000f000
[16062.611193] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000002
[16062.611199] 80000948 00000000 00808c8c
[16062.611200] ADMA registers dump from offset 0x10880 to 0x108e8
[16062.611215] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[16062.611230] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[16062.611245] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000002
[16062.611252] 80000948 00000000 00000000
[16062.611252] ADMA registers dump from offset 0x11000 to 0x11068
[16062.611268] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[16062.611283] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 0000f000
[16062.611298] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000002
[16062.611305] 80000948 00000000 00808c8c
[16062.611305] ADMA registers dump from offset 0x11080 to 0x110e8
[16062.611320] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[16062.611335] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[16062.611351] 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000002
[16062.611357] 80000948 00000000 00000000
[16062.611503] woal_request_fw failed
[16062.611507] Firmware Init Failed
[16062.615267] Free module params
[16062.615375] woal_pcie_probe: failed
[16062.615379] wlan_pcie 0000:03:00.1: probe with driver wlan_pcie failed with error -14
[16062.615407] wlan: Register to Bus Driver Done
[16062.615408] wlan: Driver loaded successfully
1,605件の閲覧回数
shaun_wu
Hello @cvd21073
Could you double check firmware are saved in /lib/firmware/nxp?
Best Regards
Shaun
1,568件の閲覧回数
cvd21073
Hello @shaun_wu ,
thanks for your support. Currently I'm discovered following firmware problem:
The WiFi module firmware fails to initialize properly after a warm reboot of my Linux machine. However, it works correctly in the following scenarios:
1. After a cold reboot (by removing power cable)
2. When I manually bring down the driver and firmware before reboot, then bring them up after reboot
Workaround:
Currently, I'm using this sequence before reboot to ensure WiFi functionality:
# Before reboot
sudo nmcli radio wifi off
sudo modprobe -r moal
sudo modprobe -r mlan # After reboot sudo nmcli radio wifi on sudo modprobe mlan
sudo modprobe moal
Kind regards
1,553件の閲覧回数
shaun_wu
Hello @cvd21073
with warm reboot, the firmware saved in chip will not be flashed. That might be reason.
Best Regards
Shaun
1,531件の閲覧回数
cvd21073
Hello @shaun_wu ,
Are there any way to fix this issue with warm boot?
1,510件の閲覧回数
shaun_wu
Hello @cvd21073
It is like a common feature of nxp wifi chip.
Best Regards
Shaun
1,503件の閲覧回数
cvd21073
Thanks @shaun_wu ,
Can you please help me with another request?
When i was building driver inside mwifiex, i have used next command, because i have architecture of x86_64:
sudo make -C /usr/src/kernels/6.12.0-55.32.1.el10_0.x86_64 M=$(pwd) ARCH=x86_64 CROSS_COMPILE= modules
I have successfully builded mlan.ko and moal.ko, but i cannot find anywhere mlan_util, uap_util or mlanutl, uaputl utilities from NXP. Could you guide me, what i should do in order to use these utilities.
Thanks in advance
1,488件の閲覧回数
shaun_wu
Hello @cvd21073
For different topic, you could create a new subject to discuss. We will have holiday next week, my colleagues will help you.
Best Regards
Shaun
%3CLINGO-SUB%20id%3D%22lingo-sub-2171996%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E3%83%AF%E3%82%A4%E3%83%A4%E3%83%AC%E3%82%B9%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%82%AC%E3%82%A4%E3%83%89%3A%20mwifiex%E3%80%81Lattepanda%20Sigma%20%E3%81%AE%20PCIe%20Wi-Fi%20%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%80%81AlmaLinux%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2171996%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%20class%3D%22%22%3E%3CSPAN%3ENXP%E3%83%86%E3%82%AF%E3%83%8B%E3%82%AB%E3%83%AB%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%83%81%E3%83%BC%E3%83%A0%E6%A7%98%3CBR%20%2F%3E%3CBR%20%2F%3EAlmaLinux%2010%20%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%20LattePanda%20Sigma%20(Intel%20CPU)%20%E3%81%A7%20Wi-Fi%20%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%20Wi-Fi%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%20-%20JODY-W377-00B%3CBR%20%2F%3E%E3%83%81%E3%83%83%E3%83%97%E3%82%BB%E3%83%83%E3%83%88%20-%20NXP%2088W9098%20%2F%2088Q9098%3CBR%20%2F%3E%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%A8%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E6%89%8B%E9%A0%86%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%81%94%E5%8D%94%E5%8A%9B%E3%82%92%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E6%95%AC%E5%85%B7%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2176442%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Wireless%20Module%20Guidence%3A%20mwifiex%2C%20Firmware%20on%20PCIe%20Wi-Fi%20on%20Lattepanda%20Sigma%2C%20AlmaLinux%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2176442%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F254980%22%20target%3D%22_blank%22%3E%40cvd21073%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E7%95%B0%E3%81%AA%E3%82%8B%E3%83%88%E3%83%94%E3%83%83%E3%82%AF%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%E8%AD%B0%E8%AB%96%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AE%E6%96%B0%E3%81%97%E3%81%84%E4%B8%BB%E9%A1%8C%E3%82%92%E4%BD%9C%E6%88%90%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%E6%9D%A5%E9%80%B1%E3%81%AF%E4%BC%91%E6%97%A5%E3%81%A7%E3%81%99%E3%81%AE%E3%81%A7%E3%80%81%E5%90%8C%E5%83%9A%E3%81%8C%E3%81%8A%E6%89%8B%E4%BC%9D%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%82%B7%E3%83%A7%E3%83%BC%E3%83%B3%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2175895%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Wireless%20Module%20Guidence%3A%20mwifiex%2C%20Firmware%20on%20PCIe%20Wi-Fi%20on%20Lattepanda%20Sigma%2C%20AlmaLinux%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2175895%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F186613%22%20target%3D%22_blank%22%3E%40shaun_wu%3C%2FA%3E%20%E3%80%81%3CBR%20%2F%3E%3CBR%20%2F%3E%E5%88%A5%E3%81%AE%E3%83%AA%E3%82%AF%E3%82%A8%E3%82%B9%E3%83%88%E3%81%AB%E3%82%82CAN%E3%81%94%E5%8D%94%E5%8A%9B%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%3F%3CBR%20%2F%3Emwifiex%20%E5%86%85%E3%81%A7%E3%83%93%E3%83%AB%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%82%92%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A8%E3%81%8D%E3%80%81%E3%82%A2%E3%83%BC%E3%82%AD%E3%83%86%E3%82%AF%E3%83%81%E3%83%A3%E3%81%8C%20x86_64%20%E3%81%A7%E3%81%82%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CDIV%3E%3CDIV%3E%3CSPAN%3Esudo%20make%3C%2FSPAN%3E%20%3CSPAN%3E-C%3C%2FSPAN%3E%20%3CSPAN%3E%2Fusr%2Fsrc%2Fkernels%2F6.12.0-55.32.1.el10_0.x86_64%3C%2FSPAN%3E%3CSPAN%3EM%3D%3C%2FSPAN%3E%20%3CSPAN%3E%24(%3C%2FSPAN%3E%20%3CSPAN%3Epwd%3C%2FSPAN%3E%20%3CSPAN%3E)%3C%2FSPAN%3E%20%3CSPAN%3EARCH%3Dx86_64%3C%2FSPAN%3E%20%3CSPAN%3ECROSS_COMPILE%3D%3C%2FSPAN%3E%3CSPAN%3E%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%3CBR%20%2F%3E%3C%2FSPAN%3E%3CBR%20%2F%3Emlan.ko%E3%81%A8moal.ko%E3%81%AE%E6%A7%8B%E7%AF%89%E3%81%AB%E6%88%90%E5%8A%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81NXP%E3%81%AEmlan_util%E3%80%81uap_util%E3%80%81mlanutl%E3%80%81uaputl%E3%83%A6%E3%83%BC%E3%83%86%E3%82%A3%E3%83%AA%E3%83%86%E3%82%A3%E3%81%8C%E3%81%A9%E3%81%93%E3%81%AB%E3%82%82%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E3%83%A6%E3%83%BC%E3%83%86%E3%82%A3%E3%83%AA%E3%83%86%E3%82%A3%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%81%A9%E3%81%86%E3%81%99%E3%82%8C%E3%81%B0%E3%81%84%E3%81%84%E3%81%8B%E6%95%99%E3%81%88%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82%3CBR%20%2F%3E%E5%89%8D%E3%82%82%E3%81%A3%E3%81%A6%E6%84%9F%E8%AC%9D%E3%81%97%E3%81%BE%E3%81%99%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2175368%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Wireless%20Module%20Guidence%3A%20mwifiex%2C%20Firmware%20on%20PCIe%20Wi-Fi%20on%20Lattepanda%20Sigma%2C%20AlmaLinux%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2175368%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F254980%22%20target%3D%22_blank%22%3E%40cvd21073%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81NXP%20WiFi%20%E3%83%81%E3%83%83%E3%83%97%E3%81%AE%E5%85%B1%E9%80%9A%E6%A9%9F%E8%83%BD%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%82%82%E3%81%AE%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%82%B7%E3%83%A7%E3%83%BC%E3%83%B3%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2174953%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Wireless%20Module%20Guidence%3A%20mwifiex%2C%20Firmware%20on%20PCIe%20Wi-Fi%20on%20Lattepanda%20Sigma%2C%20AlmaLinux%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2174953%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F186613%22%20target%3D%22_blank%22%3E%40shaun_wu%E3%81%95%E3%82%93%3C%2FA%3E%E3%80%81%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%82%A6%E3%82%A9%E3%83%BC%E3%83%A0%E3%83%96%E3%83%BC%E3%83%88%E3%81%A7%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%3F%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2174629%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Wireless%20Module%20Guidence%3A%20mwifiex%2C%20Firmware%20on%20PCIe%20Wi-Fi%20on%20Lattepanda%20Sigma%2C%20AlmaLinux%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2174629%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F254980%22%20target%3D%22_blank%22%3E%40cvd21073%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%82%A6%E3%82%A9%E3%83%BC%E3%83%A0%E3%83%AA%E3%83%96%E3%83%BC%E3%83%88%E3%81%A7%E3%81%AF%E3%80%81%E3%83%81%E3%83%83%E3%83%97%E3%81%AB%E4%BF%9D%E5%AD%98%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AF%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%95%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%9D%E3%82%8C%E3%81%8C%E7%90%86%E7%94%B1%E3%81%8B%E3%82%82%E3%81%97%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%82%B7%E3%83%A7%E3%83%BC%E3%83%B3%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2174060%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Wireless%20Module%20Guidence%3A%20mwifiex%2C%20Firmware%20on%20PCIe%20Wi-Fi%20on%20Lattepanda%20Sigma%2C%20AlmaLinux%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2174060%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F186613%22%20target%3D%22_blank%22%3E%40shaun_wu%E3%81%95%E3%82%93%3C%2FA%3E%E3%80%81%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E7%8F%BE%E5%9C%A8%E3%80%81%E6%AC%A1%E3%81%AE%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%8C%E7%99%BA%E8%A6%8B%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3A%3CBR%20%2F%3E%20%3CSPAN%3ELinux%E3%83%9E%E3%82%B7%E3%83%B3%E3%81%AE%E3%82%A6%E3%82%A9%E3%83%BC%E3%83%A0%E3%83%AA%E3%83%96%E3%83%BC%E3%83%88%E5%BE%8C%E3%80%81WiFi%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%AE%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%8F%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%B7%E3%83%8A%E3%83%AA%E3%82%AA%E3%81%A7%E3%81%AF%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3C%2FSPAN%3E%201.%E9%9B%BB%E6%BA%90%E3%82%B1%E3%83%BC%E3%83%96%E3%83%AB%E3%82%92%E5%A4%96%E3%81%97%E3%81%A6%E5%86%8D%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%9F%E5%BE%8C%3CBR%20%2F%3E2.%20%E5%86%8D%E8%B5%B7%E5%8B%95%E5%89%8D%E3%81%AB%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%A8%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E6%89%8B%E5%8B%95%E3%81%A7%E5%81%9C%E6%AD%A2%E3%81%97%E3%80%81%E5%86%8D%E8%B5%B7%E5%8B%95%E5%BE%8C%E3%81%AB%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%9F%E5%A0%B4%E5%90%88%3CBR%20%2F%3E%3CSTRONG%3E%3CSPAN%3E%E5%9B%9E%E9%81%BF%E7%AD%96%3A%3C%2FSPAN%3E%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CSPAN%3E%E7%8F%BE%E5%9C%A8%E3%80%81WiFi%20%E6%A9%9F%E8%83%BD%E3%82%92%E7%A2%BA%E4%BF%9D%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%80%81%E5%86%8D%E8%B5%B7%E5%8B%95%E5%89%8D%E3%81%AB%E6%AC%A1%E3%81%AE%E3%82%B7%E3%83%BC%E3%82%B1%E3%83%B3%E3%82%B9%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20translate%3D%22no%22%3E%3CSPAN%20class%3D%22%22%3E%23%20Before%20reboot%3C%2FSPAN%3E%0A%3CSPAN%20class%3D%22%22%3Esudo%3C%2FSPAN%3E%20nmcli%20radio%20wifi%20off%0A%3CSPAN%20class%3D%22%22%3Esudo%20modprobe%20-r%20moal%3CBR%20%2F%3E%3C%2FSPAN%3Esudo%20modprobe%20-r%20mlan%0A%0A%3CSPAN%20class%3D%22%22%3E%23%20After%20reboot%3C%2FSPAN%3E%0A%3CSPAN%20class%3D%22%22%3Esudo%3C%2FSPAN%3E%20nmcli%20radio%20wifi%20on%0A%3CSPAN%20class%3D%22%22%3Esudo%3C%2FSPAN%3E%20modprobe%20mlan%3CBR%20%2F%3Esudo%20modprobe%20moal%3C%2FPRE%3E%3CP%3E%E6%95%AC%E5%85%B7%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2173895%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Wireless%20Module%20Guidence%3A%20mwifiex%2C%20Firmware%20on%20PCIe%20Wi-Fi%20on%20Lattepanda%20Sigma%2C%20AlmaLinux%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2173895%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F254980%22%20target%3D%22_blank%22%3E%40cvd21073%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%8C%20%2Flib%2Ffirmware%2Fnxp%20%E3%81%AB%E4%BF%9D%E5%AD%98%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E3%82%82%E3%81%86%E4%B8%80%E5%BA%A6%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%82%B7%E3%83%A7%E3%83%BC%E3%83%B3%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2172930%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Wireless%20Module%20Guidence%3A%20mwifiex%2C%20Firmware%20on%20PCIe%20Wi-Fi%20on%20Lattepanda%20Sigma%2C%20AlmaLinux%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2172930%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%94%E6%8C%87%E5%B0%8E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E8%B5%B7%E5%8B%95%E3%81%A7%E5%95%8F%E9%A1%8C%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%83%AD%E3%82%B0%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3A%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%5B16055.070437%5Dwlan%3A%20MWLAN%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%AE%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%81%BF%3CBR%20%2F%3E%5B16055.070688%5Dwlan%3A%20%E3%83%90%E3%82%B9%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%AB%E7%99%BB%E9%8C%B2...%3CBR%20%2F%3E%20%5B16055.070761%5Dusbcore%3A%20%E6%96%B0%E3%81%97%E3%81%84%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%20usbxxx%20%E3%82%92%E7%99%BB%E9%8C%B2%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%5B16055.071025%5DPCI%20%E3%83%A1%E3%83%A2%E3%83%AA%E3%83%9E%E3%83%83%E3%83%97%20Virt0%3A%200000000043335f46%20PCI%20%E3%83%A1%E3%83%A2%E3%83%AA%E3%83%9E%E3%83%83%E3%83%97%20Virt2%3A%20000000004afdb115%3CBR%20%2F%3E%20%5B16055.071042%5D%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%E3%83%8F%E3%83%B3%E3%83%89%E3%83%AB%E3%82%AA%E3%83%9A%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%80%81%E3%82%AB%E3%83%BC%E3%83%89%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%82%BF%E3%82%A4%E3%83%97%3A%200x206%3CBR%20%2F%3E%20%5B16055.071044%5D%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%81%8B%E3%82%89rps%E3%81%8C0%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%82%8B%3CBR%20%2F%3E%5B16055.071045%5D%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BFcfg%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E6%8C%87%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%5B16055.071051%5Drx_work%3D1%20cpu_num%3D16%3CBR%20%2F%3E%20%5B16055.071053%5Dmoal_recv_amsdu_packet%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%3CBR%20%2F%3E%5B16055.071059%5DMLAN%20%E3%82%A2%E3%83%80%E3%83%97%E3%82%BF%E6%93%8D%E4%BD%9C%E3%81%AE%E6%8E%A5%E7%B6%9A%E3%80%82card_type%20%E3%81%AF%200x206%20%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%5B16055.074216%5D%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E3%83%AA%E3%82%AF%E3%82%A8%E3%82%B9%E3%83%88%3A%20nxp%2Fpcieuart9098_combo_v1.bin%3CBR%20%2F%3E%20%5B16055.342741%5Dprog_fw%3A%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%AE%E5%AE%8C%E4%BA%86%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E5%86%8D%E8%A9%A6%E8%A1%8C%E5%9B%9E%E6%95%B0%20%3D%2010001%3CBR%20%2F%3E%20%5B16058.642099%5DFW%E3%81%8C%E6%99%82%E9%96%93%E5%86%85%E3%81%AB%E3%82%A2%E3%82%AF%E3%83%86%E3%82%A3%E3%83%96%E5%8C%96%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%20%5B16058.642107%5Dwlan_dnld_fw%20%E5%A4%B1%E6%95%97%20ret%3D0xffffffff%3CBR%20%2F%3E%20%5B16058.642110%5DWLAN%3A%20nowwait%3A%200%20%E3%81%A7%20FW%20%E3%81%AE%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%5B16058.642119%5D%E6%A7%8B%E6%88%90%E3%82%B9%E3%83%9A%E3%83%BC%E3%82%B9%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%3A%3CBR%20%2F%3E%20%5B16058.642124%5D%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%3A0x00%20%E5%80%A4%3D0x2b431b4b%3CBR%20%2F%3E%20%5B16058.642127%5D%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%3A0x04%20%E5%80%A4%3D0x00100406%3CBR%20%2F%3E%20%5B16058.642130%5D%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%3A0x10%20%E5%80%A4%3D0x3c20000c%3CBR%20%2F%3E%20%5B16058.642133%5D%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%3A0x18%20%E5%80%A4%3D0x3c30000c%3CBR%20%2F%3E%20%5B16058.642136%5D%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%3A0x2c%20%E5%80%A4%3D0x2b431b4b%3CBR%20%2F%3E%20%5B16058.642139%5D%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%3A0x3c%20%E5%80%A4%3D0x00000105%3CBR%20%2F%3E%20%5B16058.642142%5D%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%3A0x44%20%E5%80%A4%3D0x00000008%3CBR%20%2F%3E%20%5B16058.642145%5D%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%3A0x80%20%E5%80%A4%3D0x10120143%3CBR%20%2F%3E%20%5B16058.642148%5D%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%3A0x98%20%E5%80%A4%3D0x00000400%3CBR%20%2F%3E%20%5B16058.642152%5D%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%3A0x170%20%E5%80%A4%3D0x0001001e%3CBR%20%2F%3E%20%5B16058.642156%5DFW%20%E3%82%B9%E3%82%AF%E3%83%A9%E3%83%83%E3%83%81%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%3A%3CBR%20%2F%3E%20%5B16058.642159%5D%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%3A0x1c90%20%E5%80%A4%3D0xfedcba00%3CBR%20%2F%3E%20%5B16058.642162%5D%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%3A0x1c98%20%E5%80%A4%3D0x0%3CBR%20%2F%3E%20%5B16058.642165%5D%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%3A0x1c9c%20%E5%80%A4%3D0x0%3CBR%20%2F%3E%20%5B16058.742176%5D%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%3A0x1c98%20%E5%80%A4%3D0x0%3CBR%20%2F%3E%20%5B16058.742180%5D%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%3A0x1c9c%20%E5%80%A4%3D0x0%3CBR%20%2F%3E%20%5B16058.842186%5D%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%AF%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%880x1c98%E3%81%8B%E3%82%890x1c9f%E3%81%BE%E3%81%A7%E3%83%80%E3%83%B3%E3%83%97%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%3CBR%20%2F%3E%5B16058.842193%5D%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%88%200x1c20%20%E3%81%8B%E3%82%89%200x1c9c%20%E3%81%BE%E3%81%A7%E3%81%AE%20PCIE%20%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%3A%3CBR%20%2F%3E%20%5B16058.842209%5D00000000%2000000002%200000004f%2000000000%20ffffffff%2000000002%2000000000%2000000000%3CBR%20%2F%3E%20%5B16058.842224%5D00000000%2000000000%2000000000%2000000000%2000000000%2000000000%2000000000%3CBR%20%2F%3E%20%5B16058.842240%5D2005b000%2000000000%2000000010%2000000000%20008047e3%20c8701424%2000000000%2000000000%3CBR%20%2F%3E%20%5B16058.842256%5D00000000%2000000000%2000000000%2000000000%20fedcba00%2000000000%2000000000%2000000000%3C%2FP%3E%3CP%3E%5B16058.842257%5DADMA%20Tx%2FRx%2FEvent%2FCmd%2FCmdResp%20%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%3A%3CBR%20%2F%3E%20%5B16058.842258%5DADMA%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%AF%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%880x10000%E3%81%8B%E3%82%890x10068%E3%81%BE%E3%81%A7%E3%83%80%E3%83%B3%E3%83%97%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3E%5B16058.842273%5D00100000%201e488000%2000000000%20c010ad64%2000000000%2000000000%2000000000%2000000000%3CBR%20%2F%3E%20%5B16058.842289%5D00000000%2000000001%2000000000%20000000000%2000000000%2000000000%200000f002%3CBR%20%2F%3E%20%5B16058.842304%5D00000000%2000000000%2000000000%2000000000%2000000000%2000000000%2000000002%3CBR%20%2F%3E%20%5B16058.842310%5D80000948%2000000000%2000808c8c%3CBR%20%2F%3E%20%5B16058.842311%5DADMA%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%AF%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%880x10800%E3%81%8B%E3%82%890x10868%E3%81%BE%E3%81%A7%E3%83%80%E3%83%B3%E3%83%97%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20%5B16058.842326%5D00000000%2000000000%2000000000%2000000000%2000000000%2000000000%2000000000%3CBR%20%2F%3E%20%5B16058.842342%5D00000000%2000000000%2000000000%2000000000%2000000000%2000000000%200000f000%3CBR%20%2F%3E%20%5B16058.842357%5D00000000%2000000000%2000000000%2000000000%2000000000%2000000000%2000000002%3CBR%20%2F%3E%20%5B16058.842363%5D80000948%2000000000%2000808c8c%3CBR%20%2F%3E%20%5B16058.842364%5DADMA%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%AF%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%880x10880%E3%81%8B%E3%82%890x108e8%E3%81%BE%E3%81%A7%E3%83%80%E3%83%B3%E3%83%97%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20%5B16058.842379%5D00000000%2000000000%2000000000%2000000000%2000000000%2000000000%2000000000%3CBR%20%2F%3E%20%5B16058.842395%5D00000000%2000000000%2000000000%2000000000%2000000000%2000000000%2000000000%3CBR%20%2F%3E%20%5B16058.842410%5D00000000%2000000000%2000000000%2000000000%2000000000%2000000000%2000000002%3CBR%20%2F%3E%20%5B16058.842416%5D80000948%2000000000%2000000000%3CBR%20%2F%3E%20%5B16058.842417%5DADMA%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%AF%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%880x11000%E3%81%8B%E3%82%890x11068%E3%81%BE%E3%81%A7%E3%83%80%E3%83%B3%E3%83%97%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3E%5B16058.842432%5D00000000%2000000000%2000000000%2000000000%2000000000%2000000000%2000000000%3CBR%20%2F%3E%20%5B16058.842447%5D00000000%2000000000%2000000000%2000000000%2000000000%2000000000%200000f000%3CBR%20%2F%3E%20%5B16058.842463%5D00000000%2000000000%2000000000%2000000000%2000000000%2000000000%2000000002%3CBR%20%2F%3E%20%5B16058.842469%5D80000948%2000000000%2000808c8c%3CBR%20%2F%3E%20%5B16058.842470%5DADMA%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%AF%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%880x11080%E3%81%8B%E3%82%890x110e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woal_request_fw%20%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%5B16058.842684%5D%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%5B16058.846592%5D%E3%83%95%E3%83%AA%E3%83%BC%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%3CBR%20%2F%3E%5B16058.846698%5Dwoal_pcie_probe%3A%20%E5%A4%B1%E6%95%97%3CBR%20%2F%3E%5B16058.846701%5Dwlan_pcie%200000%3A03%3A00.0%3A%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%20wlan_pcie%20%E3%81%AE%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%81%8C%E3%82%A8%E3%83%A9%E3%83%BC%20-14%20%E3%81%A7%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%5B16058.846773%5DPCI%20%E3%83%A1%E3%83%A2%E3%83%AA%20%E3%83%9E%E3%83%83%E3%83%97%20Virt0%3A%20000000007132ef2a%20PCI%20%E3%83%A1%E3%83%A2%E3%83%AA%20%E3%83%9E%E3%83%83%E3%83%97%20Virt2%3A%20000000007089599c%3CBR%20%2F%3E%20%5B16058.846777%5D%E3%83%9E%E3%82%A6%E3%83%B3%E3%83%88%E3%83%8F%E3%83%B3%E3%83%89%E3%83%AB%E3%82%AA%E3%83%9A%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%80%81%E3%82%AB%E3%83%BC%E3%83%89%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%82%BF%E3%82%A4%E3%83%97%3A%200x206%3CBR%20%2F%3E%20%5B16058.846780%5D%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%81%8B%E3%82%89rps%E3%81%8C0%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%82%8B%3CBR%20%2F%3E%5B16058.846781%5D%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BFcfg%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E6%8C%87%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%5B16058.846786%5Drx_work%3D1%20cpu_num%3D16%3CBR%20%2F%3E%20%5B16058.846787%5Dmoal_recv_amsdu_packet%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%3CBR%20%2F%3E%5B16058.846791%5DMLAN%20%E3%82%A2%E3%83%80%E3%83%97%E3%82%BF%E6%93%8D%E4%BD%9C%E3%81%AE%E6%8E%A5%E7%B6%9A%E3%80%82card_type%20%E3%81%AF%200x206%20%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%5B16058.851016%5D%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E3%83%AA%E3%82%AF%E3%82%A8%E3%82%B9%E3%83%88%3A%20nxp%2Fpcieuart9098_combo_v1.bin%3CBR%20%2F%3E%20%5B16059.110692%5Dprog_fw%3A%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%AE%E5%AE%8C%E4%BA%86%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E5%86%8D%E8%A9%A6%E8%A1%8C%E5%9B%9E%E6%95%B0%20%3D%2010001%3CBR%20%2F%3E%20%5B16062.410938%5DFW%E3%81%8C%E6%99%82%E9%96%93%E5%86%85%E3%81%AB%E3%82%A2%E3%82%AF%E3%83%86%E3%82%A3%E3%83%96%E5%8C%96%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%20%5B16062.410943%5Dwlan_dnld_fw%20%E5%A4%B1%E6%95%97%20ret%3D0xffffffff%3CBR%20%2F%3E%20%5B16062.410946%5DWLAN%3A%20nowwait%3A%200%20%E3%81%A7%20FW%20%E3%81%AE%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%5B16062.410955%5D%E6%A7%8B%E6%88%90%E3%82%B9%E3%83%9A%E3%83%BC%E3%82%B9%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%3A%3CBR%20%2F%3E%20%5B16062.410959%5D%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%3A0x00%20%E5%80%A4%3D0x2b441b4b%3CBR%20%2F%3E%20%5B16062.410962%5D%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%3A0x04%20%E5%80%A4%3D0x00100406%3CBR%20%2F%3E%20%5B16062.410965%5D%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%3A0x10%20%E5%80%A4%3D0x3c10000c%3CBR%20%2F%3E%20%5B16062.410968%5D%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%3A0x18%20%E5%80%A4%3D0x6c900004%3CBR%20%2F%3E%20%5B16062.410971%5D%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%3A0x2c%20%E5%80%A4%3D0x2b441b4b%3CBR%20%2F%3E%20%5B16062.410974%5D%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%3A0x3c%20%E5%80%A4%3D0x00000203%3CBR%20%2F%3E%20%5B16062.410977%5D%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%3A0x44%20%E5%80%A4%3D0x00000008%3CBR%20%2F%3E%20%5B16062.410980%5D%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%3A0x80%20%E5%80%A4%3D0x10120143%3CBR%20%2F%3E%20%5B16062.410983%5D%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%3A0x98%20%E5%80%A4%3D0x00000000%3CBR%20%2F%3E%20%5B16062.410987%5D%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%3A0x170%20%E5%80%A4%3D0x0001001e%3CBR%20%2F%3E%20%5B16062.410991%5DFW%20%E3%82%B9%E3%82%AF%E3%83%A9%E3%83%83%E3%83%81%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%3A%3CBR%20%2F%3E%20%5B16062.410994%5D%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%3A0x1c90%20%E5%80%A4%3D0xfedcba00%3CBR%20%2F%3E%20%5B16062.410997%5D%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%3A0x1c98%20%E5%80%A4%3D0x0%3CBR%20%2F%3E%20%5B16062.411000%5D%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%3A0x1c9c%20%E5%80%A4%3D0x0%3CBR%20%2F%3E%20%5B16062.511010%5D%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%3A0x1c98%20%E5%80%A4%3D0x0%3CBR%20%2F%3E%20%5B16062.511014%5D%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%3A0x1c9c%20%E5%80%A4%3D0x0%3CBR%20%2F%3E%20%5B16062.611020%5D%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%AF%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%880x1c98%E3%81%8B%E3%82%890x1c9f%E3%81%BE%E3%81%A7%E3%83%80%E3%83%B3%E3%83%97%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%3CBR%20%2F%3E%5B16062.611029%5D%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%88%200x1c20%20%E3%81%8B%E3%82%89%200x1c9c%20%E3%81%BE%E3%81%A7%E3%81%AE%20PCIE%20%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%3A%3CBR%20%2F%3E%20%5B16062.611045%5D00000000%2000000002%200000004f%2000000000%20ffffffff%2000000002%2000000000%2000000000%3CBR%20%2F%3E%20%5B16062.611061%5D00000000%2000000000%2000000000%2000000000%2000000000%2000000000%2000000000%3CBR%20%2F%3E%20%5B16062.611076%5D1e8f8000%2000000000%2000000010%2000000000%20008047e3%20c8701424%2000000000%2000000000%3CBR%20%2F%3E%20%5B16062.611092%5D00000000%2000000000%2000000000%2000000000%20fedcba00%2000000000%2000000000%2000000000%3C%2FP%3E%3CP%3E%5B16062.611094%5DADMA%20Tx%2FRx%2FEvent%2FCmd%2FCmdResp%20%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%3A%3CBR%20%2F%3E%20%5B16062.611095%5DADMA%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%AF%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%880x10000%E3%81%8B%E3%82%890x10068%E3%81%BE%E3%81%A7%E3%83%80%E3%83%B3%E3%83%97%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3E%5B16062.611110%5D00000000%2000000000%2000000000%2000000000%2000000000%2000000000%2000000000%3CBR%20%2F%3E%20%5B16062.611125%5D00000000%2000000000%2000000000%2000000000%2000000000%2000000000%200000f000%3CBR%20%2F%3E%20%5B16062.611140%5D00000000%2000000000%2000000000%2000000000%2000000000%2000000000%2000000002%3CBR%20%2F%3E%20%5B16062.611147%5D80000948%2000000000%2000808c8c%3CBR%20%2F%3E%20%5B16062.611148%5DADMA%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%AF%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%880x10800%E3%81%8B%E3%82%890x10868%E3%81%BE%E3%81%A7%E3%83%80%E3%83%B3%E3%83%97%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20%5B16062.611163%5D00000000%2000000000%2000000000%2000000000%2000000000%2000000000%2000000000%3CBR%20%2F%3E%20%5B16062.611178%5D00000000%2000000000%2000000000%2000000000%2000000000%2000000000%200000f000%3CBR%20%2F%3E%20%5B16062.611193%5D00000000%2000000000%2000000000%2000000000%2000000000%2000000000%2000000002%3CBR%20%2F%3E%20%5B16062.611199%5D80000948%2000000000%2000808c8c%3CBR%20%2F%3E%20%5B16062.611200%5DADMA%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%AF%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%880x10880%E3%81%8B%E3%82%890x108e8%E3%81%BE%E3%81%A7%E3%83%80%E3%83%B3%E3%83%97%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%20%5B16062.611215%5D00000000%2000000000%2000000000%2000000000%2000000000%2000000000%2000000000%3CBR%20%2F%3E%20%5B16062.611230%5D00000000%2000000000%2000000000%2000000000%2000000000%2000000000%2000000000%3CBR%20%2F%3E%20%5B16062.611245%5D00000000%2000000000%2000000000%2000000000%2000000000%2000000000%2000000002%3CBR%20%2F%3E%20%5B16062.611252%5D80000948%2000000000%2000000000%3CBR%20%2F%3E%20%5B16062.611252%5DADMA%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%AF%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%880x11000%E3%81%8B%E3%82%890x11068%E3%81%BE%E3%81%A7%E3%83%80%E3%83%B3%E3%83%97%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3E%5B16062.611268%5D00000000%2000000000%2000000000%2000000000%2000000000%2000000000%2000000000%3CBR%20%2F%3E%20%5B16062.611283%5D00000000%2000000000%2000000000%2000000000%2000000000%2000000000%200000f000%3CBR%20%2F%3E%20%5B16062.611298%5D00000000%2000000000%2000000000%2000000000%2000000000%2000000000%2000000002%3CBR%20%2F%3E%20%5B16062.611305%5D80000948%2000000000%2000808c8c%3CBR%20%2F%3E%20%5B16062.611305%5DADMA%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%AF%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%880x11080%E3%81%8B%E3%82%890x110e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woal_request_fw%20%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%5B16062.611507%5D%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%5B16062.615267%5D%E3%83%95%E3%83%AA%E3%83%BC%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%3CBR%20%2F%3E%5B16062.615375%5Dwoal_pcie_probe%3A%20%E5%A4%B1%E6%95%97%3CBR%20%2F%3E%5B16062.615379%5Dwlan_pcie%200000%3A03%3A00.1%3A%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%20wlan_pcie%20%E3%81%AE%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%81%8C%E3%82%A8%E3%83%A9%E3%83%BC%20-14%20%E3%81%A7%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%5B16062.615407%5Dwlan%3A%20%E3%83%90%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%B8%E3%81%AE%E7%99%BB%E9%8C%B2%E3%81%8C%E5%AE%8C%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%5B16062.615408%5Dwlan%3A%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%8C%E6%AD%A3%E5%B8%B8%E3%81%AB%E3%83%AD%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2172530%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Wireless%20Module%20Guidence%3A%20mwifiex%2C%20Firmware%20on%20PCIe%20Wi-Fi%20on%20Lattepanda%20Sigma%2C%20AlmaLinux%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2172530%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F254980%22%20target%3D%22_blank%22%3E%40cvd21073%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E3%81%93%E3%81%93%E3%81%A7%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%A8%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%20%E3%83%AA%E3%83%B3%E3%82%AF%E3%82%92%E6%8F%90%E4%BE%9B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fdocs.nxp.com%2Fbundle%2FUM11675%2Fpage%2Ftopics%2Foverview.html%3F_gl%3D1*1aasm7x*_gcl_au*NTMyNjUwMTEzLjE3NTgyNjIxNzQ.*_ga*OTc4NDkyODQ4LjE3NTgyNjIxNzU.*_ga_WM5LE0KMSH*czE3NTgyNjIxNzQkbzEkZzEkdDE3NTgyNjI0NTEkajMkbDAkaDE0NzE0NTEx%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EUM11675%20%7C%20NXP%20Semiconductors%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%82%92%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E3%81%AB%E7%A7%BB%E6%A4%8D%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%80%82Intel%20%E3%81%8C%E3%82%AC%E3%82%A4%E3%83%89%E3%82%92%E6%8F%90%E4%BE%9B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%82%B7%E3%83%A7%E3%83%BC%E3%83%B3%3C%2FP%3E%3C%2FLINGO-BODY%3E
