L6.6.3 iw612 load txpower_cfg fail
4,741 次查看
Chihyu_Lin
I am trying add txpwrlimit_cfg while loading WiFi driver, but got the following error, same settings/files in L6.1.55 was fine. And without set txpwrlimit_cfg parameter, WiFi driver load succesfully and working fine.
root@imx93:~# modprobe moal mod_para=nxp/wifi_mod_para.conf
[ 17.532015] mlan: loading out-of-tree module taints kernel.
[ 17.578136] wlan: Loading MWLAN driver
[ 17.585593] wlan: Register to Bus Driver...
[ 17.600828] vendor=0x0471 device=0x0205 class=0 function=1
[ 17.606578] Attach moal handle ops, card interface type: 0x109
[ 17.612532] rps set to 0 from module param
[ 17.617918] SDIW612: init module param from usr cfg
[ 17.623162] card_type: SDIW612, config block: 0
[ 17.627774] cfg80211_wext=0xf
[ 17.630789] max_vir_bss=1
[ 17.633448] cal_data_cfg=none
[ 17.636416] ps_mode = 1
[ 17.641499] auto_ds = 1
[ 17.643983] host_mlme=enable
[ 17.649504] fw_name=nxp/sduart_nw61x_v1.bin.se
[ 17.654084] txpwrlimit_cfg=nxp/txpower_QSM_US.bin
[ 17.658916] SDIO: max_segs=128 max_seg_size=65535
[ 17.663765] rx_work=1 cpu_num=2
[ 17.666995] Enable moal_recv_amsdu_packet
[ 17.671074] Attach mlan adapter operations.card_type is 0x109.
[ 17.682854] wlan: Enable TX SG mode
[ 17.686391] wlan: Enable RX SG mode
[ 17.693610] Request firmware: nxp/sduart_nw61x_v1.bin.se
[ 18.046530] Wlan: FW download over, firmwarelen=1004248 downloaded 916048
[ 18.453634] WLAN FW is active
[ 18.456624] on_time is 18307253173
[ 18.460061] Download txpwrlimit_cfg=nxp/txpower_US.bin
[ 18.487779] VDLL image: len=88200
[ 18.519055] fw_cap_info=0x487cff03, dev_cap_mask=0xffffffff
[ 18.524681] uuid: 521d887a0a925da4a1fe6a6f39966212
[ 18.529497] max_p2p_conn = 8, max_sta_conn = 16
[ 18.559956] Register NXP 802.11 Adapter mlan0
[ 18.566109] wlan: uap%d set max_mtu 2000
[ 18.574646] Register NXP 802.11 Adapter uap0
[ 18.608521] Register NXP 802.11 Adapter wfd0
[ 18.619407] wlan: version = SDIW612---18.99.2.p66.17-MM6X18437.p3-GPL-(FP92)
[ 18.636305] wlan: Register to Bus Driver Done
[ 18.645522] wlan: Driver loaded successfully
[ 21.266693] FW trigger fw dump
[ 21.269817] =====FW trigger dump====
[ 21.273726] ==== Start Receive FW dump event ====
[ 21.278586] === START DRIVER INFO DUMP===
[ 21.278825] FW in debug mode (0xe3)
[ 21.394221] Drv info total bytes = 336781 (0x5238d)
[ 21.399129] === DRIVER INFO DUMP END===
[ 22.215633] ==== FW DUMP END: 1336880 bytes ====
[ 22.224118] fw dump total length is 1336892
[ 22.228385] Start to process hanging
[ 22.232045] Cancel all pending cmd and txrx queue
[ 22.236901] WIFI auto_fw_reload: fw_reload=1
[ 22.241239] ========START IN-BAND RESET===========
[ 22.246180] woal_reset_intf: get bss info failed
[ 22.250927] Cancel all pending cmd and txrx queue
[ 22.390250] woal_close: woal_disconnect failed
[ 22.662577] FW wake up
[ 22.666271] SDIO Trigger FW In-band Reset success
[ 22.666304] SDIO: max_segs=128 max_seg_size=65535
[ 22.677190] rx_work=1 cpu_num=2
[ 22.681162] Enable moal_recv_amsdu_packet
[ 22.686153] Attach mlan adapter operations.card_type is 0x109.
[ 22.693545] wlan: Enable TX SG mode
[ 22.697059] wlan: Enable RX SG mode
[ 22.701957] Request firmware: nxp/sduart_nw61x_v1.bin.se
[ 23.067701] Wlan: FW download over, firmwarelen=1004248 downloaded 916048
[ 29.077402] Fail to poll firmware status: firmwarestat=0x0
[ 29.082928] FW failed to be active in time!
[ 29.087135] wlan_dnld_fw fail ret=0xffffffff
[ 29.091440] WLAN: Fail download FW with nowwait: 0
[ 29.096577] SDIO Func0 (0x0-0x9): 43 03 02 02 03 00 00 02 03 00
[ 29.103437] SDIO Func1 (0x10-0x17): 00 00 00 00 00 00 00 00
[ 29.109526] SDIO Func1: (0x8) 00 (0x58) 00 (0x5c) 0d (0x5d) 00 (0x60) 01 (0x61) 00 (0x62) 00 (0x64) 10 (0x65) 00 (0x66) 00 (0x68) 00 (0x69) 00 (0x6a) 00
[ 29.123829] SDIO Func1 (0xe8-0xff): 00 00 00 00 50 fa 0d 00 24 14 70 c8 ab 37 80 00 00 00 00 00 01 00 00 00
[ 29.235469] SDIO Func1 (0xe8-0xff): 00 00 00 00 50 fa 0d 00 24 14 70 c8 ab 37 80 00 00 00 00 00 01 00 00 00
[ 29.245502] woal_request_fw failed
[ 29.248901] Firmware Init Failed
[ 29.252479] SDIO Func0 (0x0-0x9): 43 03 02 02 03 00 00 02 03 00
[ 29.258736] SDIO Func1 (0x10-0x17): 00 00 00 00 00 00 00 00
[ 29.264745] SDIO Func1: (0x8) 00 (0x58) 00 (0x5c) 0d (0x5d) 00 (0x60) 01 (0x61) 00 (0x62) 00 (0x64) 10 (0x65) 00 (0x66) 00 (0x68) 00 (0x69) 00 (0x6a) 00
[ 29.279066] SDIO Func1 (0xe8-0xff): 00 00 00 00 50 fa 0d 00 24 14 70 c8 ab 37 80 00 00 00 00 00 01 00 00 00
[ 29.389834] SDIO Func1 (0xe8-0xff): 00 00 00 00 50 fa 0d 00 24 14 70 c8 ab 37 80 00 00 00 00 00 01 00 00 00
[ 29.489860] Free module params
[ 29.492947] ========END IN-BAND RESET===========
标签 (3)
4,531 次查看
shaun_wu
Hello @Chihyu_Lin
Could you try 6.6.23 on this problem? We have a similar fix on 6.6.23 release.
Best Regards
Shaun
9 回复数
4,722 次查看
shaun_wu
Hello @Chihyu_Lin
Could you sahre the version you get these error report?
Best Regards
Shaun
4,718 次查看
Chihyu_Lin
Platform is i.MX 9302A1 Base on imx-6.6.3-1.0.0
NXP-wlan-sdk SRCREV=:a84df583155bad2a396a937056805550bdf655ab"
wlan: version = SDIW612---18.99.2.p66.17-MM6X18423.p6-GPL-(FP92)
And wifi_mod_para.conf setting was.
SDIW612 = {
cfg80211_wext=0xf
max_vir_bss=1
cal_data_cfg=none
ps_mode=1
auto_ds=1
host_mlme=1
4,656 次查看
shaun_wu
Hello @Chihyu_Lin
Could you share txpower_US.bin you used?
Best Rergards
Shaun
4,650 次查看
Chihyu_Lin
Hi @shaun_wu
Attached our Tx power file, system can't allow upload binary file.
4,590 次查看
shaun_wu
Hello @Chihyu_Lin
We are able to reproduce your issue, and we are internally tracking this problem. I'll update to you when we get progress. Thanks!
Best Regards
Shaun
4,532 次查看
shaun_wu
Hello @Chihyu_Lin
Best Regards
Shaun
4,520 次查看
Chihyu_Lin
Hello @shaun_wu
Thanks, after force change FW and driver to 6.6.23 fixed this issue.
root@quilt-imx93-qsm:~# modprobe moal mod_para=nxp/wifi_mod_para_qsm.conf
[ 22.253697] mlan: loading out-of-tree module taints kernel.
[ 22.317581] wlan: Loading MWLAN driver
[ 22.326493] wlan: Register to Bus Driver...
[ 22.338429] vendor=0x0471 device=0x0205 class=0 function=1
[ 22.344079] Attach moal handle ops, card interface type: 0x109
[ 22.349968] rps set to 0 from module param
[ 22.355413] SDIW612: init module param from usr cfg
[ 22.360371] card_type: SDIW612, config block: 0
[ 22.364935] cfg80211_wext=0xf
[ 22.367927] max_vir_bss=1
[ 22.370569] cal_data_cfg=none
[ 22.373554] ps_mode = 1
[ 22.376013] auto_ds = 1
[ 22.378482] host_mlme=enable
[ 22.381390] fw_name=nxp/sduart_nw61x_v1.bin.se
[ 22.385857] txpwrlimit_cfg=nxp/txpower_US.bin
[ 22.390616] SDIO: max_segs=128 max_seg_size=65535
[ 22.395338] rx_work=1 cpu_num=2
[ 22.398522] Enable moal_recv_amsdu_packet
[ 22.402675] Attach mlan adapter operations.card_type is 0x109.
[ 22.414743] wlan: Enable TX SG mode
[ 22.418371] wlan: Enable RX SG mode
[ 22.426370] Request firmware: nxp/sduart_nw61x_v1.bin.se
[ 22.778840] Wlan: FW download over, firmwarelen=1038668 downloaded 936668
[ 23.181312] WLAN FW is active
[ 23.184329] on_time is 22921111967
[ 23.187759] Download txpwrlimit_cfg=nxp/txpower_US.bin
[ 23.221031] VDLL image: len=102000
[ 23.265041] fw_cap_info=0x487cff03, dev_cap_mask=0xffffffff
[ 23.270673] uuid: 521d887a0a925da4a1fe6a6f39966212
[ 23.275483] max_p2p_conn = 8, max_sta_conn = 16
[ 23.410178] Register NXP 802.11 Adapter mlan0
[ 23.414909] wlan: uap%d set max_mtu 2000
[ 23.424961] Register NXP 802.11 Adapter uap0
[ 23.541433] Register NXP 802.11 Adapter wfd0
[ 23.547371] wlan: version = SDIW612---18.99.3.p10.1-MM6X18437.p21-GPL-(FP92)
[ 23.584774] wlan: Register to Bus Driver Done
[ 23.591295] wlan: Driver loaded successfully
4,719 次查看
shaun_wu
Hello @Chihyu_Lin
The problem might be tx_pwr config already downloaded, you download again then error reported. You could try cut off power supply then reboot the system.
Best Regards
Shaun
4,716 次查看
Chihyu_Lin
It's only one place could to set tx power in wifi_mod_para.conf, and I upgrade nxp-wlan-sdk in L6.1.55 same initial command and txpower_US.bin without any problem.
%3CLINGO-SUB%20id%3D%22lingo-sub-1890021%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EL6.6.3%20iw612%20load%20txpower_cfg%20fail%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1890021%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%3C%2FP%3E%3CP%3E%E6%88%91%E5%B0%9D%E8%AF%95%E5%9C%A8%E5%8A%A0%E8%BD%BD%20WiFi%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E6%97%B6%E6%B7%BB%E5%8A%A0%20txpwrlimit_cfg%EF%BC%8C%E4%BD%86%E5%87%BA%E7%8E%B0%E4%BB%A5%E4%B8%8B%E9%94%99%E8%AF%AF%EF%BC%8CL6.1.55%20%E4%B8%AD%E7%9A%84%E7%9B%B8%E5%90%8C%E8%AE%BE%E7%BD%AE%2F%E6%96%87%E4%BB%B6%E5%BE%88%E5%A5%BD%E3%80%82%E5%B9%B6%E4%B8%94%E6%97%A0%E9%9C%80%E8%AE%BE%E7%BD%AE%20txpwrlimit_cfg%20%E5%8F%82%E6%95%B0%EF%BC%8CWiFi%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%8D%B3%E5%8F%AF%E6%88%90%E5%8A%9F%E5%8A%A0%E8%BD%BD%E5%B9%B6%E6%AD%A3%E5%B8%B8%E5%B7%A5%E4%BD%9C%E3%80%82%3C%2FP%3E%3CP%3Eroot%40imx93%3A~%23%20modprobe%20moal%20mod_para%3Dnxp%2Fwifi_mod_para.conf%3CBR%20%2F%3E%5B%2017.532015%5D%20mlan%3A%E5%8A%A0%E8%BD%BD%E6%A0%91%E5%A4%96%E6%A8%A1%E5%9D%97%E4%BC%9A%E6%B1%A1%E6%9F%93%E5%86%85%E6%A0%B8%E3%80%82%3CBR%20%2F%3E%5B17.578136%5DWLAN%EF%BC%9A%E6%AD%A3%E5%9C%A8%E5%8A%A0%E8%BD%BDMWLAN%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3CBR%20%2F%3E%5B%2017.585593%5D%20wlan%3A%E6%B3%A8%E5%86%8C%E5%88%B0%E6%80%BB%E7%BA%BF%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F...%3CBR%20%2F%3E%20%5B17.600828%5D%E4%BE%9B%E5%BA%94%E5%95%86%3D0x0471%E8%AE%BE%E5%A4%87%3D0x0205%E7%B1%BB%3D0%E5%8A%9F%E8%83%BD%3D1%3CBR%20%2F%3E%20%5B17.606578%5D%E9%99%84%E5%8A%A0moal%E5%8F%A5%E6%9F%84%E6%93%8D%E4%BD%9C%EF%BC%8C%E5%8D%A1%E6%8E%A5%E5%8F%A3%E7%B1%BB%E5%9E%8B%EF%BC%9A0x109%3CBR%20%2F%3E%20%5B17.612532%5Drps%E4%BB%8E%E6%A8%A1%E5%9D%97%E5%8F%82%E6%95%B0%E8%AE%BE%E7%BD%AE%E4%B8%BA0%3CBR%20%2F%3E%20%5B17.617918%5DSDIW612%3A%E6%9D%A5%E8%87%AAusr%20cfg%E7%9A%84%E5%88%9D%E5%A7%8B%E5%8C%96%E6%A8%A1%E5%9D%97%E5%8F%82%E6%95%B0%3CBR%20%2F%3E%5B17.623162%5D%E5%8D%A1%E7%B1%BB%E5%9E%8B%EF%BC%9ASDIW612%EF%BC%8C%E9%85%8D%E7%BD%AE%E5%9D%97%EF%BC%9A0%3CBR%20%2F%3E%20%5B17.627774%5Dcfg80211_wext%3D0xf%3CBR%20%2F%3E%20%5B17.630789%5D%E6%9C%80%E5%A4%A7%E8%99%9A%E6%8B%9F%E5%99%A8BSS%3D1%3CBR%20%2F%3E%20%5B17.633448%5D%E6%A0%A1%E5%87%86%E6%95%B0%E6%8D%AE_cfg%3D%E6%97%A0%3CBR%20%2F%3E%5B17.636416%5Dps_%E6%A8%A1%E5%BC%8F%3D1%3CBR%20%2F%3E%20%5B17.641499%5D%E8%87%AA%E5%8A%A8_ds%3D1%3CBR%20%2F%3E%20%5B17.643983%5Dhost_mlme%3D%E5%90%AF%E7%94%A8%3CBR%20%2F%3E%5B17.649504%5Dfw_name%3Dnxp%2Fsduart_nw61x_v1.bin.se%3CBR%20%2F%3E%5B17.654084%5Dtxpwrlimit_cfg%3Dnxp%2Ftxpower_QSM_US.bin%3CBR%20%2F%3E%5B17.658916%5DSDIO%EF%BC%9Amax_segs%20%3D%20128%20max_seg_size%20%3D%2065535%3CBR%20%2F%3E%20%5B17.663765%5Drx_work%3D1%20cpu_num%3D2%3CBR%20%2F%3E%20%5B17.666995%5D%E5%90%AF%E7%94%A8moal_recv_amsdu_packet%3CBR%20%2F%3E%20%5B17.671074%5D%20%E8%BF%9E%E6%8E%A5mlan%E9%80%82%E9%85%8D%E5%99%A8%E6%93%8D%E4%BD%9C.card_type%E4%B8%BA0x109%E3%80%82%3CBR%20%2F%3E%5B17.682854%5DWLAN%EF%BC%9A%E5%90%AF%E7%94%A8TX%20SG%E6%A8%A1%E5%BC%8F%3CBR%20%2F%3E%5B17.686391%5Dwlan%3A%E5%90%AF%E7%94%A8RX%20SG%E6%A8%A1%E5%BC%8F%3CBR%20%2F%3E%5B17.693610%5D%E8%AF%B7%E6%B1%82%E5%9B%BA%E4%BB%B6%EF%BC%9Anxp%2Fsduart_nw61x_v1.bin.se%3CBR%20%2F%3E%5B%2018.046530%5D%20Wlan%3A%20FW%20%E4%B8%8B%E8%BD%BD%E7%BB%93%E6%9D%9F%EF%BC%8Cfirmwarelen%3D1004248%20%E5%B7%B2%E4%B8%8B%E8%BD%BD%20916048%3CBR%20%2F%3E%20%5B18.453634%5DWLAN%E5%9B%BA%E4%BB%B6%E5%A4%84%E4%BA%8E%E6%B4%BB%E5%8A%A8%E7%8A%B6%E6%80%81%3CBR%20%2F%3E%5B18.456624%5D%E5%87%86%E6%97%B6%E4%B8%BA18307253173%3CBR%20%2F%3E%20%5B18.460061%5D%E4%B8%8B%E8%BD%BDtxpwrlimit_cfg%3Dnxp%2Ftxpower_US.bin%3CBR%20%2F%3E%20%5B18.487779%5DVDLL%E5%9B%BE%E5%83%8F%EF%BC%9Alen%3D88200%3CBR%20%2F%3E%20%5B18.519055%5Dfw_cap_info%3D0x487cff03%EF%BC%8Cdev_cap_mask%3D0xffffffff%3CBR%20%2F%3E%20%5B18.524681%5DUUID%EF%BC%9A521d887a0a925da4a1fe6a6f39966212%3CBR%20%2F%3E%20%5B18.529497%5D%E6%9C%80%E5%A4%A7p2p_%E8%BF%9E%E6%8E%A5%E6%95%B0%3D8%EF%BC%8C%E6%9C%80%E5%A4%A7sta_%E8%BF%9E%E6%8E%A5%E6%95%B0%3D16%3CBR%20%2F%3E%20%5B18.559956%5D%E6%B3%A8%E5%86%8CNXP%20802.11%E9%80%82%E9%85%8D%E5%99%A8mlan0%3CBR%20%2F%3E%20%5B18.566109%5Dwlan%EF%BC%9Auap%25d%E8%AE%BE%E7%BD%AEmax_mtu%202000%3CBR%20%2F%3E%20%5B18.574646%5D%E6%B3%A8%E5%86%8CNXP%20802.11%E9%80%82%E9%85%8D%E5%99%A8uap0%3CBR%20%2F%3E%20%5B18.608521%5D%E6%B3%A8%E5%86%8CNXP%20802.11%E9%80%82%E9%85%8D%E5%99%A8wfd0%3CBR%20%2F%3E%20%5B18.619407%5D%20wlan%EF%BC%9A%E7%89%88%E6%9C%AC%3DSDIW612---18.99.2.p66.17-MM6X18437.p3-GPL-(FP92)%3CBR%20%2F%3E%5B18.636305%5Dwlan%3A%E5%90%91%E6%80%BB%E7%BA%BF%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E6%B3%A8%E5%86%8C%E5%AE%8C%E6%88%90%3CBR%20%2F%3E%5B18.645522%5Dwlan%3A%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%8A%A0%E8%BD%BD%E6%88%90%E5%8A%9F%3CBR%20%2F%3E%5B21.266693%5D%3CSTRONG%3E%3CFONT%20color%3D%22%23FF0000%22%3E%E5%9B%BA%E4%BB%B6%E8%A7%A6%E5%8F%91%E5%9B%BA%E4%BB%B6%E8%BD%AC%E5%82%A8%3C%2FFONT%3E%3C%2FSTRONG%3E%3CBR%20%2F%3E%5B21.269817%5D%20%3D%3D%3D%3D%3DFW%E8%A7%A6%E5%8F%91%E5%99%A8%E8%BD%AC%E5%82%A8%3D%3D%3D%3D%3CBR%20%2F%3E%20%5B%2021.273726%5D%20%3D%3D%3D%3D%20%E5%BC%80%E5%A7%8B%E6%8E%A5%E6%94%B6%20FW%20%E8%BD%AC%E5%82%A8%E4%BA%8B%E4%BB%B6%20%3D%3D%3D%3D%3CBR%20%2F%3E%20%5B%2021.278586%5D%20%3D%3D%3D%20%E5%BC%80%E5%A7%8B%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E4%BF%A1%E6%81%AF%E8%BD%AC%E5%82%A8%3D%3D%3D%3CBR%20%2F%3E%20%5B21.278825%5D%E5%9B%BA%E4%BB%B6%E5%A4%84%E4%BA%8E%E8%B0%83%E8%AF%95%E6%A8%A1%E5%BC%8F%EF%BC%880xe3%EF%BC%89%3CBR%20%2F%3E%20%5B21.394221%5D%20Drv%20%E4%BF%A1%E6%81%AF%E6%80%BB%E5%AD%97%E8%8A%82%E6%95%B0%20%3D%20336781%20(0x5238d)%3CBR%20%2F%3E%20%5B%2021.399129%5D%20%3D%3D%3D%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E4%BF%A1%E6%81%AF%E8%BD%AC%E5%82%A8%E7%BB%93%E6%9D%9F%3D%3D%3D%3CBR%20%2F%3E%20%5B%2022.215633%5D%20%3D%3D%3D%3D%20FW%20DUMP%20%E7%BB%93%E6%9D%9F%EF%BC%9A1336880%20%E5%AD%97%E8%8A%82%20%3D%3D%3D%3D%3CBR%20%2F%3E%20%5B22.224118%5Dfw%20dump%20%E6%80%BB%E9%95%BF%E5%BA%A6%E4%B8%BA%201336892%3CBR%20%2F%3E%20%5B22.228385%5D%E5%BC%80%E5%A7%8B%E5%A4%84%E7%90%86%E6%82%AC%E6%8C%82%3CBR%20%2F%3E%5B%2022.232045%5D%20%E5%8F%96%E6%B6%88%E6%89%80%E6%9C%89%E5%BE%85%E5%A4%84%E7%90%86%E7%9A%84%E5%91%BD%E4%BB%A4%E5%92%8C%20txrx%20%E9%98%9F%E5%88%97%3CBR%20%2F%3E%5B22.236901%5DWIFI%E8%87%AA%E5%8A%A8%E9%87%8D%E6%96%B0%E5%8A%A0%E8%BD%BD%EF%BC%9Afw_%E9%87%8D%E6%96%B0%E5%8A%A0%E8%BD%BD%3D1%3CBR%20%2F%3E%20%5B%2022.241239%5D%20%3D%3D%3D%3D%3D%3D%3D%3D%E5%BC%80%E5%A7%8B%E5%B8%A6%E5%86%85%E9%87%8D%E7%BD%AE%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3CBR%20%2F%3E%20%5B22.246180%5D%20woal_reset_intf%3A%E8%8E%B7%E5%8F%96bss%E4%BF%A1%E6%81%AF%E5%A4%B1%E8%B4%A5%3CBR%20%2F%3E%5B%2022.250927%5D%20%E5%8F%96%E6%B6%88%E6%89%80%E6%9C%89%E5%BE%85%E5%A4%84%E7%90%86%E7%9A%84%20cmd%20%E5%92%8C%20txrx%20%E9%98%9F%E5%88%97%3CBR%20%2F%3E%5B22.390250%5Dwoal_close%3Awoal_disconnect%E5%A4%B1%E8%B4%A5%3CBR%20%2F%3E%5B22.662577%5DFW%E9%86%92%E6%9D%A5%3CBR%20%2F%3E%5B22.666271%5D%20SDIO%E8%A7%A6%E5%8F%91FW%E5%B8%A6%E5%86%85%E5%A4%8D%E4%BD%8D%E6%88%90%E5%8A%9F%3CBR%20%2F%3E%5B22.666304%5DSDIO%EF%BC%9Amax_segs%20%3D%20128%20max_seg_size%20%3D%2065535%3CBR%20%2F%3E%20%5B22.677190%5Drx_work%3D1%20cpu_num%3D2%3CBR%20%2F%3E%20%5B22.681162%5D%E5%90%AF%E7%94%A8moal_recv_amsdu_packet%3CBR%20%2F%3E%20%5B22.686153%5D%20%E8%BF%9E%E6%8E%A5%20mlan%20%E9%80%82%E9%85%8D%E5%99%A8%E6%93%8D%E4%BD%9C.card_type%20%E4%B8%BA%200x109%E3%80%82%3CBR%20%2F%3E%5B22.693545%5DWLAN%EF%BC%9A%E5%90%AF%E7%94%A8TX%20SG%E6%A8%A1%E5%BC%8F%3CBR%20%2F%3E%5B22.697059%5Dwlan%3A%E5%90%AF%E7%94%A8RX%20SG%E6%A8%A1%E5%BC%8F%3CBR%20%2F%3E%5B22.701957%5D%E8%AF%B7%E6%B1%82%E5%9B%BA%E4%BB%B6%EF%BC%9Anxp%2Fsduart_nw61x_v1.bin.se%3CBR%20%2F%3E%5B%2023.067701%5D%20Wlan%EF%BC%9AFW%20%E4%B8%8B%E8%BD%BD%E7%BB%93%E6%9D%9F%EF%BC%8Cfirmwarelen%3D1004248%20%E5%B7%B2%E4%B8%8B%E8%BD%BD%20916048%3CBR%20%2F%3E%20%5B%2029.077402%5D%20%E6%97%A0%E6%B3%95%E8%BD%AE%E8%AF%A2%E5%9B%BA%E4%BB%B6%E7%8A%B6%E6%80%81%EF%BC%9Afirmwarestat%3D0x0%3CBR%20%2F%3E%20%5B%2029.082928%5D%20FW%20%E6%9C%AA%E8%83%BD%E5%8F%8A%E6%97%B6%E6%BF%80%E6%B4%BB%EF%BC%81%3CBR%20%2F%3E%20%5B29.087135%5Dwlan_dnld_fw%E5%A4%B1%E8%B4%A5ret%20%3D%200xffffffff%3CBR%20%2F%3E%20%5B%2029.091440%5D%20%3CFONT%20color%3D%22%23FF0000%22%3E%3CSTRONG%3EWLAN%EF%BC%9A%E4%B8%8B%E8%BD%BD%E5%9B%BA%E4%BB%B6%E5%A4%B1%E8%B4%A5%EF%BC%8Cnowwait%EF%BC%9A0%3C%2FSTRONG%3E%3C%2FFONT%3E%3CBR%20%2F%3E%20%5B29.096577%5DSDIO%E5%8A%9F%E8%83%BD0%EF%BC%880x0-0x9%EF%BC%89%EF%BC%9A43%2003%2002%2002%2003%2000%2000%2002%2003%2000%3CBR%20%2F%3E%20%5B29.103437%5DSDIO%E5%8A%9F%E8%83%BD1%EF%BC%880x10-0x17%EF%BC%89%EF%BC%9A00%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%20%5B29.109526%5D%20SDIO%20%E5%8A%9F%E8%83%BD1%EF%BC%9A%EF%BC%880x8%EF%BC%8900%EF%BC%880x58%EF%BC%8900%EF%BC%880x5c%EF%BC%890d%EF%BC%880x5d%EF%BC%8900%EF%BC%880x60%EF%BC%8901%EF%BC%880x61%EF%BC%8900%EF%BC%880x62%EF%BC%8900%EF%BC%880x64%EF%BC%8910%EF%BC%880x65%EF%BC%8900%EF%BC%880x66%EF%BC%8900%EF%BC%880x68%EF%BC%8900%EF%BC%880x69%EF%BC%8900%EF%BC%880x6a%EF%BC%8900%3CBR%20%2F%3E%20%5B29.123829%5DSDIO%E5%8A%9F%E8%83%BD1%EF%BC%880xe8-0xff%EF%BC%89%EF%BC%9A00%2000%2000%2000%2050%20fa%200d%2000%2024%2014%2070%20c8%20ab%2037%2080%2000%2000%2000%2000%2000%2001%2000%2000%2000%3CBR%20%2F%3E%20%5B29.235469%5DSDIO%E5%8A%9F%E8%83%BD1%EF%BC%880xe8-0xff%EF%BC%89%EF%BC%9A00%2000%2000%2000%2050%20fa%200d%2000%2024%2014%2070%20c8%20ab%2037%2080%2000%2000%2000%2000%2000%2001%2000%2000%2000%3CBR%20%2F%3E%20%5B29.245502%5Dwoal_request_fw%E5%A4%B1%E8%B4%A5%3CBR%20%2F%3E%5B29.248901%5D%E5%9B%BA%E4%BB%B6%E5%88%9D%E5%A7%8B%E5%8C%96%E5%A4%B1%E8%B4%A5%3CBR%20%2F%3E%5B29.252479%5DSDIO%E5%8A%9F%E8%83%BD0%EF%BC%880x0-0x9%EF%BC%89%EF%BC%9A43%2003%2002%2002%2003%2000%2000%2002%2003%2000%3CBR%20%2F%3E%20%5B29.258736%5DSDIO%E5%8A%9F%E8%83%BD1%EF%BC%880x10-0x17%EF%BC%89%EF%BC%9A00%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%20%5B29.264745%5D%20SDIO%E5%8A%9F%E8%83%BD1%EF%BC%9A%EF%BC%880x8%EF%BC%8900%EF%BC%880x58%EF%BC%8900%EF%BC%880x5c%EF%BC%890d%EF%BC%880x5d%EF%BC%8900%EF%BC%880x60%EF%BC%8901%EF%BC%880x61%EF%BC%8900%EF%BC%880x62%EF%BC%8900%EF%BC%880x64%EF%BC%8910%EF%BC%880x65%EF%BC%8900%EF%BC%880x66%EF%BC%8900%EF%BC%880x68%EF%BC%8900%EF%BC%880x69%EF%BC%8900%EF%BC%880x6a%EF%BC%8900%3CBR%20%2F%3E%20%5B29.279066%5DSDIO%E5%8A%9F%E8%83%BD1%EF%BC%880xe8-0xff%EF%BC%89%EF%BC%9A00%2000%2000%2000%2050%20fa%200d%2000%2024%2014%2070%20c8%20ab%2037%2080%2000%2000%2000%2000%2000%2001%2000%2000%2000%3CBR%20%2F%3E%20%5B29.389834%5DSDIO%E5%8A%9F%E8%83%BD1%EF%BC%880xe8-0xff%EF%BC%89%EF%BC%9A00%2000%2000%2000%2050%20fa%200d%2000%2024%2014%2070%20c8%20ab%2037%2080%2000%2000%2000%2000%2000%2001%2000%2000%2000%3CBR%20%2F%3E%20%5B29.489860%5D%E5%85%8D%E8%B4%B9%E6%A8%A1%E5%9D%97%E5%8F%82%E6%95%B0%3CBR%20%2F%3E%5B%2029.492947%5D%20%3D%3D%3D%3D%3D%3D%3D%3D%E7%BB%93%E6%9D%9F%E5%B8%A6%E5%86%85%E5%A4%8D%E4%BD%8D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1890021%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EOS%20LINUX%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3E%E4%BA%A7%E5%93%81%EF%BC%9AWiFi%20IW6XX%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3E%E5%8D%8F%E8%AE%AE%EF%BC%9AWi-Fi%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1902221%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20L6.6.3%20iw612%20load%20txpower_cfg%20fail%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1902221%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F186613%22%20target%3D%22_blank%22%3E%40shaun_wu%3C%2FA%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%E8%B0%A2%E8%B0%A2%EF%BC%8C%E5%BC%BA%E5%88%B6%E5%B0%86%20FW%20%E5%92%8C%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E6%9B%B4%E6%94%B9%E4%B8%BA%206.6.23%20%E5%90%8E%E8%A7%A3%E5%86%B3%E4%BA%86%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3Eroot%40quilt-imx93-qsm%3A~%23%20modprobe%20moal%20mod_para%3Dnxp%2Fwifi_mod_para_qsm.conf%3CBR%20%2F%3E%5B%2022.253697%5D%20mlan%3A%E5%8A%A0%E8%BD%BD%E6%A0%91%E5%A4%96%E6%A8%A1%E5%9D%97%E4%BC%9A%E6%B1%A1%E6%9F%93%E5%86%85%E6%A0%B8%E3%80%82%3CBR%20%2F%3E%5B22.317581%5DWLAN%EF%BC%9A%E6%AD%A3%E5%9C%A8%E5%8A%A0%E8%BD%BDMWLAN%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3CBR%20%2F%3E%5B%2022.326493%5D%20wlan%3A%E6%B3%A8%E5%86%8C%E5%88%B0%E6%80%BB%E7%BA%BF%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F...%3CBR%20%2F%3E%20%5B22.338429%5D%E4%BE%9B%E5%BA%94%E5%95%86%3D0x0471%E8%AE%BE%E5%A4%87%3D0x0205%E7%B1%BB%3D0%E5%8A%9F%E8%83%BD%3D1%3CBR%20%2F%3E%20%5B22.344079%5D%E9%99%84%E5%8A%A0moal%E5%8F%A5%E6%9F%84%E6%93%8D%E4%BD%9C%EF%BC%8C%E5%8D%A1%E6%8E%A5%E5%8F%A3%E7%B1%BB%E5%9E%8B%EF%BC%9A0x109%3CBR%20%2F%3E%20%5B22.349968%5Drps%E4%BB%8E%E6%A8%A1%E5%9D%97%E5%8F%82%E6%95%B0%E8%AE%BE%E7%BD%AE%E4%B8%BA0%3CBR%20%2F%3E%20%5B22.355413%5DSDIW612%3A%E6%9D%A5%E8%87%AAusr%20cfg%E7%9A%84%E5%88%9D%E5%A7%8B%E5%8C%96%E6%A8%A1%E5%9D%97%E5%8F%82%E6%95%B0%3CBR%20%2F%3E%5B22.360371%5D%E5%8D%A1%E7%B1%BB%E5%9E%8B%EF%BC%9ASDIW612%EF%BC%8C%E9%85%8D%E7%BD%AE%E5%9D%97%EF%BC%9A0%3CBR%20%2F%3E%20%5B22.364935%5Dcfg80211_wext%3D0xf%3CBR%20%2F%3E%20%5B22.367927%5D%E6%9C%80%E5%A4%A7%E8%99%9A%E6%8B%9F%E5%99%A8BSS%3D1%3CBR%20%2F%3E%20%5B22.370569%5D%E6%A0%A1%E5%87%86%E6%95%B0%E6%8D%AE_cfg%3D%E6%97%A0%3CBR%20%2F%3E%5B22.373554%5Dps_%E6%A8%A1%E5%BC%8F%3D1%3CBR%20%2F%3E%20%5B22.376013%5D%E8%87%AA%E5%8A%A8_ds%3D1%3CBR%20%2F%3E%20%5B22.378482%5Dhost_mlme%3D%E5%90%AF%E7%94%A8%3CBR%20%2F%3E%5B22.381390%5Dfw_name%3Dnxp%2Fsduart_nw61x_v1.bin.se%3CBR%20%2F%3E%5B22.385857%5Dtxpwrlimit_cfg%3Dnxp%2Ftxpower_US.bin%3CBR%20%2F%3E%5B22.390616%5DSDIO%EF%BC%9Amax_segs%20%3D%20128%20max_seg_size%20%3D%2065535%3CBR%20%2F%3E%20%5B22.395338%5Drx_work%3D1%20cpu_num%3D2%3CBR%20%2F%3E%20%5B22.398522%5D%E5%90%AF%E7%94%A8moal_recv_amsdu_packet%3CBR%20%2F%3E%20%5B22.402675%5D%20%E8%BF%9E%E6%8E%A5%20mlan%20%E9%80%82%E9%85%8D%E5%99%A8%E6%93%8D%E4%BD%9C.card_type%20%E4%B8%BA%200x109%E3%80%82%3CBR%20%2F%3E%5B22.414743%5DWLAN%EF%BC%9A%E5%90%AF%E7%94%A8TX%20SG%E6%A8%A1%E5%BC%8F%3CBR%20%2F%3E%5B22.418371%5Dwlan%3A%E5%90%AF%E7%94%A8RX%20SG%E6%A8%A1%E5%BC%8F%3CBR%20%2F%3E%5B22.426370%5D%E8%AF%B7%E6%B1%82%E5%9B%BA%E4%BB%B6%EF%BC%9Anxp%2Fsduart_nw61x_v1.bin.se%3CBR%20%2F%3E%5B%2022.778840%5D%20Wlan%3A%20FW%20%E4%B8%8B%E8%BD%BD%E7%BB%93%E6%9D%9F%EF%BC%8Cfirmwarelen%3D1038668%20%E5%B7%B2%E4%B8%8B%E8%BD%BD%20936668%3CBR%20%2F%3E%20%5B23.181312%5DWLAN%E5%9B%BA%E4%BB%B6%E5%A4%84%E4%BA%8E%E6%B4%BB%E5%8A%A8%E7%8A%B6%E6%80%81%3CBR%20%2F%3E%5B23.184329%5D%E5%87%86%E6%97%B6%E4%B8%BA22921111967%3CBR%20%2F%3E%20%5B23.187759%5D%E4%B8%8B%E8%BD%BDtxpwrlimit_cfg%3Dnxp%2Ftxpower_US.bin%3CBR%20%2F%3E%20%5B23.221031%5DVDLL%E5%9B%BE%E5%83%8F%EF%BC%9Alen%3D102000%3CBR%20%2F%3E%20%5B23.265041%5Dfw_cap_info%3D0x487cff03%EF%BC%8Cdev_cap_mask%3D0xffffffff%3CBR%20%2F%3E%20%5B23.270673%5DUUID%EF%BC%9A521d887a0a925da4a1fe6a6f39966212%3CBR%20%2F%3E%20%5B23.275483%5D%E6%9C%80%E5%A4%A7p2p_%E8%BF%9E%E6%8E%A5%E6%95%B0%EF%BC%9D8%EF%BC%8C%E6%9C%80%E5%A4%A7sta_%E8%BF%9E%E6%8E%A5%E6%95%B0%EF%BC%9D16%3CBR%20%2F%3E%20%5B23.410178%5D%E6%B3%A8%E5%86%8CNXP%20802.11%E9%80%82%E9%85%8D%E5%99%A8mlan0%3CBR%20%2F%3E%20%5B23.414909%5Dwlan%EF%BC%9Auap%25d%E8%AE%BE%E7%BD%AEmax_mtu%202000%3CBR%20%2F%3E%20%5B23.424961%5D%E6%B3%A8%E5%86%8CNXP%20802.11%E9%80%82%E9%85%8D%E5%99%A8uap0%3CBR%20%2F%3E%20%5B23.541433%5D%E6%B3%A8%E5%86%8CNXP%20802.11%E9%80%82%E9%85%8D%E5%99%A8wfd0%3CBR%20%2F%3E%20%5B23.547371%5D%20%3CSTRONG%3E%3CFONT%20color%3D%22%23FF0000%22%3Ewlan%EF%BC%9A%E7%89%88%E6%9C%AC%3DSDIW612---18.99.3.p10.1-MM6X18437.p21-GPL-(FP92)%3C%2FFONT%3E%3C%2FSTRONG%3E%3CBR%20%2F%3E%5B23.584774%5D%20wlan%3A%E5%90%91%E6%80%BB%E7%BA%BF%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E6%B3%A8%E5%86%8C%E5%AE%8C%E6%88%90%3CBR%20%2F%3E%5B23.591295%5D%20wlan%3A%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%8A%A0%E8%BD%BD%E6%88%90%E5%8A%9F%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1901892%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20L6.6.3%20iw612%20load%20txpower_cfg%20fail%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1901892%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F223693%22%20target%3D%22_blank%22%3E%40Chihyu_Lin%3C%2FA%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E4%BD%A0%E8%83%BD%E8%AF%95%E8%AF%95%3CSPAN%3E%3CSPAN%20class%3D%22%22%3E6.6.23%20%E7%89%88%E6%9C%AC%E5%90%97%EF%BC%9F%E6%88%91%E4%BB%AC%E5%9C%A8%206.6.23%20%E7%89%88%E6%9C%AC%E4%B8%AD%E4%B9%9F%E6%9C%89%E4%B8%80%E4%B8%AA%E7%B1%BB%E4%BC%BC%E7%9A%84%E4%BF%AE%E5%A4%8D%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E%3CSPAN%20class%3D%22%22%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%3CSPAN%20class%3D%22%22%3E%E8%82%96%E6%81%A9%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1895823%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20L6.6.3%20iw612%20load%20txpower_cfg%20fail%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1895823%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F223693%22%20target%3D%22_blank%22%3E%40Chihyu_Lin%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%88%91%E4%BB%AC%E8%83%BD%E5%A4%9F%E9%87%8D%E7%8E%B0%E6%82%A8%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%8C%E5%B9%B6%E4%B8%94%E6%88%91%E4%BB%AC%E6%AD%A3%E5%9C%A8%E5%86%85%E9%83%A8%E8%B7%9F%E8%B8%AA%E6%AD%A4%E9%97%AE%E9%A2%98%E3%80%82%E5%BD%93%E6%88%91%E4%BB%AC%E5%8F%96%E5%BE%97%E8%BF%9B%E5%B1%95%E6%97%B6%EF%BC%8C%E6%88%91%E4%BC%9A%E5%90%91%E6%82%A8%E9%80%9A%E6%8A%A5%E3%80%82%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%0A%3CP%3E%E8%82%96%E6%81%A9%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1892031%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20L6.6.3%20iw612%20load%20txpower_cfg%20fail%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1892031%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F186613%22%20target%3D%22_blank%22%3E%40shaun_wu%3C%2FA%3E%3CBR%20%2F%3E%E9%99%84%E5%8A%A0%E6%88%91%E4%BB%AC%E7%9A%84%20Tx%20%E7%94%B5%E6%BA%90%E6%96%87%E4%BB%B6%EF%BC%8C%E7%B3%BB%E7%BB%9F%E4%B8%8D%E5%85%81%E8%AE%B8%E4%B8%8A%E4%BC%A0%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1891972%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20L6.6.3%20iw612%20load%20txpower_cfg%20fail%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1891972%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F223693%22%20target%3D%22_blank%22%3E%40Chihyu_Lin%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%82%A8%E8%83%BD%E5%88%86%E4%BA%AB%3CSPAN%3E%E6%82%A8%E4%BD%BF%E7%94%A8%E7%9A%84%20txpower_US.bin%20%E5%90%97%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%3E%E8%B0%A8%E8%87%B4%E9%97%AE%E5%80%99%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E8%82%96%E6%81%A9%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1890260%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20L6.6.3%20iw612%20load%20txpower_cfg%20fail%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1890260%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Ewifi_mod_para.conf%20%E4%B8%AD%E5%8F%AA%E6%9C%89%E4%B8%80%E4%B8%AA%E5%9C%B0%E6%96%B9%E5%8F%AF%E4%BB%A5%E8%AE%BE%E7%BD%AE%20tx%20%E5%8A%9F%E7%8E%87%EF%BC%8C%E6%88%91%E5%9C%A8%20L6.1.55%20%E4%B8%AD%E5%8D%87%E7%BA%A7%E4%BA%86%20nxp-wlan-sdk%E7%9B%B8%E5%90%8C%E7%9A%84%E5%88%9D%E5%A7%8B%E5%91%BD%E4%BB%A4%E5%92%8C%20txpower_US.bin%20%E6%B2%A1%E6%9C%89%E4%BB%BB%E4%BD%95%E9%97%AE%E9%A2%98%E3%80%82%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1890242%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20L6.6.3%20iw612%20load%20txpower_cfg%20fail%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1890242%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%B9%B3%E5%8F%B0%E6%98%AF%E5%9F%BA%E4%BA%8Eimx-6.6.3-1.0.0%E7%9A%84i.MX%209302A1%3CBR%20%2F%3ENXP-wlan-sdk%20SRCREV%3D%3Aa84df583155bad2a396a937056805550bdf655ab%E2%80%9D%3CBR%20%2F%3E%20wlan%EF%BC%9A%E7%89%88%E6%9C%AC%3DSDIW612---18.99.2.p66.17-MM6X18423.p6-GPL-(FP92)%3CBR%20%2F%3E%E5%B9%B6%E4%B8%94%20wifi_mod_para.conf%20%E8%AE%BE%E7%BD%AE%E6%98%AF%E3%80%82%3CBR%20%2F%3ESDIW612%20%3D%20%7B%3CBR%20%2F%3E%20cfg80211_wext%3D0xf%3CBR%20%2F%3E%E6%9C%80%E5%A4%A7%E8%99%9A%E6%8B%9F%E5%99%A8bss%3D1%3CBR%20%2F%3E%20cal_data_cfg%3D%E6%97%A0%3CBR%20%2F%3Eps_mode%3D1%3CBR%20%2F%3E%E8%87%AA%E5%8A%A8_ds%3D1%3CBR%20%2F%3E%20host_mlme%3D1%3CBR%20%2F%3E%20fw_name%3Dnxp%2Fsduart_nw61x_v1.bin.se%3CBR%20%2F%3Etxpwrlimit_cfg%3Dnxp%2Ftxpower_US.bin%3CBR%20%2F%3E%7D%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1890223%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20L6.6.3%20iw612%20load%20txpower_cfg%20fail%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1890223%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F223693%22%20target%3D%22_blank%22%3E%40Chihyu_Lin%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E9%97%AE%E9%A2%98%E5%8F%AF%E8%83%BD%E6%98%AFtx_pwr%E9%85%8D%E7%BD%AE%E5%B7%B2%E7%BB%8F%E4%B8%8B%E8%BD%BD%EF%BC%8C%E6%82%A8%E5%86%8D%E6%AC%A1%E4%B8%8B%E8%BD%BD%E7%84%B6%E5%90%8E%E6%8A%A5%E5%91%8A%E9%94%99%E8%AF%AF%E3%80%82%E6%82%A8%E5%8F%AF%E4%BB%A5%E5%B0%9D%E8%AF%95%E5%88%87%E6%96%AD%E7%94%B5%E6%BA%90%E7%84%B6%E5%90%8E%E9%87%8D%E6%96%B0%E5%90%AF%E5%8A%A8%E7%B3%BB%E7%BB%9F%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%0A%3CP%3E%E8%82%96%E6%81%A9%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1890211%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20L6.6.3%20iw612%20load%20txpower_cfg%20fail%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1890211%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F223693%22%20target%3D%22_blank%22%3E%40Chihyu_Lin%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%82%A8%E8%83%BD%E5%88%86%E4%BA%AB%E6%94%B6%E5%88%B0%E8%BF%99%E4%BA%9B%E9%94%99%E8%AF%AF%E6%8A%A5%E5%91%8A%E7%9A%84%E7%89%88%E6%9C%AC%E5%90%97%EF%BC%9F%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%0A%3CP%3E%E8%82%96%E6%81%A9%3C%2FP%3E%3C%2FLINGO-BODY%3E
