L6.6.3 iw612 load txpower_cfg fail
4,635件の閲覧回数
Chihyu_Lin
I am trying add txpwrlimit_cfg while loading WiFi driver, but got the following error, same settings/files in L6.1.55 was fine. And without set txpwrlimit_cfg parameter, WiFi driver load succesfully and working fine.
root@imx93:~# modprobe moal mod_para=nxp/wifi_mod_para.conf
[ 17.532015] mlan: loading out-of-tree module taints kernel.
[ 17.578136] wlan: Loading MWLAN driver
[ 17.585593] wlan: Register to Bus Driver...
[ 17.600828] vendor=0x0471 device=0x0205 class=0 function=1
[ 17.606578] Attach moal handle ops, card interface type: 0x109
[ 17.612532] rps set to 0 from module param
[ 17.617918] SDIW612: init module param from usr cfg
[ 17.623162] card_type: SDIW612, config block: 0
[ 17.627774] cfg80211_wext=0xf
[ 17.630789] max_vir_bss=1
[ 17.633448] cal_data_cfg=none
[ 17.636416] ps_mode = 1
[ 17.641499] auto_ds = 1
[ 17.643983] host_mlme=enable
[ 17.649504] fw_name=nxp/sduart_nw61x_v1.bin.se
[ 17.654084] txpwrlimit_cfg=nxp/txpower_QSM_US.bin
[ 17.658916] SDIO: max_segs=128 max_seg_size=65535
[ 17.663765] rx_work=1 cpu_num=2
[ 17.666995] Enable moal_recv_amsdu_packet
[ 17.671074] Attach mlan adapter operations.card_type is 0x109.
[ 17.682854] wlan: Enable TX SG mode
[ 17.686391] wlan: Enable RX SG mode
[ 17.693610] Request firmware: nxp/sduart_nw61x_v1.bin.se
[ 18.046530] Wlan: FW download over, firmwarelen=1004248 downloaded 916048
[ 18.453634] WLAN FW is active
[ 18.456624] on_time is 18307253173
[ 18.460061] Download txpwrlimit_cfg=nxp/txpower_US.bin
[ 18.487779] VDLL image: len=88200
[ 18.519055] fw_cap_info=0x487cff03, dev_cap_mask=0xffffffff
[ 18.524681] uuid: 521d887a0a925da4a1fe6a6f39966212
[ 18.529497] max_p2p_conn = 8, max_sta_conn = 16
[ 18.559956] Register NXP 802.11 Adapter mlan0
[ 18.566109] wlan: uap%d set max_mtu 2000
[ 18.574646] Register NXP 802.11 Adapter uap0
[ 18.608521] Register NXP 802.11 Adapter wfd0
[ 18.619407] wlan: version = SDIW612---18.99.2.p66.17-MM6X18437.p3-GPL-(FP92)
[ 18.636305] wlan: Register to Bus Driver Done
[ 18.645522] wlan: Driver loaded successfully
[ 21.266693] FW trigger fw dump
[ 21.269817] =====FW trigger dump====
[ 21.273726] ==== Start Receive FW dump event ====
[ 21.278586] === START DRIVER INFO DUMP===
[ 21.278825] FW in debug mode (0xe3)
[ 21.394221] Drv info total bytes = 336781 (0x5238d)
[ 21.399129] === DRIVER INFO DUMP END===
[ 22.215633] ==== FW DUMP END: 1336880 bytes ====
[ 22.224118] fw dump total length is 1336892
[ 22.228385] Start to process hanging
[ 22.232045] Cancel all pending cmd and txrx queue
[ 22.236901] WIFI auto_fw_reload: fw_reload=1
[ 22.241239] ========START IN-BAND RESET===========
[ 22.246180] woal_reset_intf: get bss info failed
[ 22.250927] Cancel all pending cmd and txrx queue
[ 22.390250] woal_close: woal_disconnect failed
[ 22.662577] FW wake up
[ 22.666271] SDIO Trigger FW In-band Reset success
[ 22.666304] SDIO: max_segs=128 max_seg_size=65535
[ 22.677190] rx_work=1 cpu_num=2
[ 22.681162] Enable moal_recv_amsdu_packet
[ 22.686153] Attach mlan adapter operations.card_type is 0x109.
[ 22.693545] wlan: Enable TX SG mode
[ 22.697059] wlan: Enable RX SG mode
[ 22.701957] Request firmware: nxp/sduart_nw61x_v1.bin.se
[ 23.067701] Wlan: FW download over, firmwarelen=1004248 downloaded 916048
[ 29.077402] Fail to poll firmware status: firmwarestat=0x0
[ 29.082928] FW failed to be active in time!
[ 29.087135] wlan_dnld_fw fail ret=0xffffffff
[ 29.091440] WLAN: Fail download FW with nowwait: 0
[ 29.096577] SDIO Func0 (0x0-0x9): 43 03 02 02 03 00 00 02 03 00
[ 29.103437] SDIO Func1 (0x10-0x17): 00 00 00 00 00 00 00 00
[ 29.109526] SDIO Func1: (0x8) 00 (0x58) 00 (0x5c) 0d (0x5d) 00 (0x60) 01 (0x61) 00 (0x62) 00 (0x64) 10 (0x65) 00 (0x66) 00 (0x68) 00 (0x69) 00 (0x6a) 00
[ 29.123829] SDIO Func1 (0xe8-0xff): 00 00 00 00 50 fa 0d 00 24 14 70 c8 ab 37 80 00 00 00 00 00 01 00 00 00
[ 29.235469] SDIO Func1 (0xe8-0xff): 00 00 00 00 50 fa 0d 00 24 14 70 c8 ab 37 80 00 00 00 00 00 01 00 00 00
[ 29.245502] woal_request_fw failed
[ 29.248901] Firmware Init Failed
[ 29.252479] SDIO Func0 (0x0-0x9): 43 03 02 02 03 00 00 02 03 00
[ 29.258736] SDIO Func1 (0x10-0x17): 00 00 00 00 00 00 00 00
[ 29.264745] SDIO Func1: (0x8) 00 (0x58) 00 (0x5c) 0d (0x5d) 00 (0x60) 01 (0x61) 00 (0x62) 00 (0x64) 10 (0x65) 00 (0x66) 00 (0x68) 00 (0x69) 00 (0x6a) 00
[ 29.279066] SDIO Func1 (0xe8-0xff): 00 00 00 00 50 fa 0d 00 24 14 70 c8 ab 37 80 00 00 00 00 00 01 00 00 00
[ 29.389834] SDIO Func1 (0xe8-0xff): 00 00 00 00 50 fa 0d 00 24 14 70 c8 ab 37 80 00 00 00 00 00 01 00 00 00
[ 29.489860] Free module params
[ 29.492947] ========END IN-BAND RESET===========
ラベル(3)
4,425件の閲覧回数
shaun_wu
Hello @Chihyu_Lin
Could you try 6.6.23 on this problem? We have a similar fix on 6.6.23 release.
Best Regards
Shaun
9 返答(返信)
4,616件の閲覧回数
shaun_wu
Hello @Chihyu_Lin
Could you sahre the version you get these error report?
Best Regards
Shaun
4,612件の閲覧回数
Chihyu_Lin
Platform is i.MX 9302A1 Base on imx-6.6.3-1.0.0
NXP-wlan-sdk SRCREV=:a84df583155bad2a396a937056805550bdf655ab"
wlan: version = SDIW612---18.99.2.p66.17-MM6X18423.p6-GPL-(FP92)
And wifi_mod_para.conf setting was.
SDIW612 = {
cfg80211_wext=0xf
max_vir_bss=1
cal_data_cfg=none
ps_mode=1
auto_ds=1
host_mlme=1
4,550件の閲覧回数
shaun_wu
Hello @Chihyu_Lin
Could you share txpower_US.bin you used?
Best Rergards
Shaun
4,544件の閲覧回数
Chihyu_Lin
Hi @shaun_wu
Attached our Tx power file, system can't allow upload binary file.
4,484件の閲覧回数
shaun_wu
Hello @Chihyu_Lin
We are able to reproduce your issue, and we are internally tracking this problem. I'll update to you when we get progress. Thanks!
Best Regards
Shaun
4,426件の閲覧回数
shaun_wu
Hello @Chihyu_Lin
Best Regards
Shaun
4,414件の閲覧回数
Chihyu_Lin
Hello @shaun_wu
Thanks, after force change FW and driver to 6.6.23 fixed this issue.
root@quilt-imx93-qsm:~# modprobe moal mod_para=nxp/wifi_mod_para_qsm.conf
[ 22.253697] mlan: loading out-of-tree module taints kernel.
[ 22.317581] wlan: Loading MWLAN driver
[ 22.326493] wlan: Register to Bus Driver...
[ 22.338429] vendor=0x0471 device=0x0205 class=0 function=1
[ 22.344079] Attach moal handle ops, card interface type: 0x109
[ 22.349968] rps set to 0 from module param
[ 22.355413] SDIW612: init module param from usr cfg
[ 22.360371] card_type: SDIW612, config block: 0
[ 22.364935] cfg80211_wext=0xf
[ 22.367927] max_vir_bss=1
[ 22.370569] cal_data_cfg=none
[ 22.373554] ps_mode = 1
[ 22.376013] auto_ds = 1
[ 22.378482] host_mlme=enable
[ 22.381390] fw_name=nxp/sduart_nw61x_v1.bin.se
[ 22.385857] txpwrlimit_cfg=nxp/txpower_US.bin
[ 22.390616] SDIO: max_segs=128 max_seg_size=65535
[ 22.395338] rx_work=1 cpu_num=2
[ 22.398522] Enable moal_recv_amsdu_packet
[ 22.402675] Attach mlan adapter operations.card_type is 0x109.
[ 22.414743] wlan: Enable TX SG mode
[ 22.418371] wlan: Enable RX SG mode
[ 22.426370] Request firmware: nxp/sduart_nw61x_v1.bin.se
[ 22.778840] Wlan: FW download over, firmwarelen=1038668 downloaded 936668
[ 23.181312] WLAN FW is active
[ 23.184329] on_time is 22921111967
[ 23.187759] Download txpwrlimit_cfg=nxp/txpower_US.bin
[ 23.221031] VDLL image: len=102000
[ 23.265041] fw_cap_info=0x487cff03, dev_cap_mask=0xffffffff
[ 23.270673] uuid: 521d887a0a925da4a1fe6a6f39966212
[ 23.275483] max_p2p_conn = 8, max_sta_conn = 16
[ 23.410178] Register NXP 802.11 Adapter mlan0
[ 23.414909] wlan: uap%d set max_mtu 2000
[ 23.424961] Register NXP 802.11 Adapter uap0
[ 23.541433] Register NXP 802.11 Adapter wfd0
[ 23.547371] wlan: version = SDIW612---18.99.3.p10.1-MM6X18437.p21-GPL-(FP92)
[ 23.584774] wlan: Register to Bus Driver Done
[ 23.591295] wlan: Driver loaded successfully
4,613件の閲覧回数
shaun_wu
Hello @Chihyu_Lin
The problem might be tx_pwr config already downloaded, you download again then error reported. You could try cut off power supply then reboot the system.
Best Regards
Shaun
4,610件の閲覧回数
Chihyu_Lin
It's only one place could to set tx power in wifi_mod_para.conf, and I upgrade nxp-wlan-sdk in L6.1.55 same initial command and txpower_US.bin without any problem.
%3CLINGO-SUB%20id%3D%22lingo-sub-1890021%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EL6.6.3%20iw612%20load%20txpower_cfg%20fail%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1890021%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%3C%2FP%3E%3CP%3EWiFi%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%AE%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%81%BF%E4%B8%AD%E3%81%ABtxpwrlimit_cfg%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%97%E3%82%88%E3%81%86%E3%81%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81L6.1.55%E3%81%A8%E5%90%8C%E3%81%98%E8%A8%AD%E5%AE%9A%2F%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%A7%E6%AC%A1%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E5%A4%A7%E4%B8%88%E5%A4%AB%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%E3%81%BE%E3%81%9F%E3%80%81txpwrlimit_cfg%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%AA%E3%81%84%E3%81%A8%E3%80%81WiFi%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%AF%E6%AD%A3%E5%B8%B8%E3%81%AB%E3%83%AD%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%80%81%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3Eroot%40imx93%3A~%23%20modprobe%20moal%20mod_para%3Dnxp%2Fwifi_mod_para.conf%3CBR%20%2F%3E%5B%2017.532015%5D%20MLAN%3A%E3%83%84%E3%83%AA%E3%83%BC%E5%A4%96%E3%81%AE%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89%E3%81%99%E3%82%8B%E3%81%A8%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%8C%E6%B1%9A%E6%9F%93%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%5B%2017.578136%5D%20wlan%3AMWLAN%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3E%5B%2017.585593%5D%20wlan%3A%E3%83%90%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%AB%E7%99%BB%E9%8C%B2...%3CBR%20%2F%3E%5B%2017.600828%5D%20vendor%3D0x0471%20device%3D0x0205%20class%3D0%20function%3D1%3CBR%20%2F%3E%5B%2017.606578%5D%20%E3%83%A2%E3%83%BC%E3%83%AB%E3%83%8F%E3%83%B3%E3%83%89%E3%83%AB%E3%82%AA%E3%83%97%E3%82%B9%E3%82%92%E5%8F%96%E3%82%8A%E4%BB%98%E3%81%91%E3%80%81%E3%82%AB%E3%83%BC%E3%83%89%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%82%BF%E3%82%A4%E3%83%97%3A0x109%3CBR%20%2F%3E%5B%2017.612532%5D%20%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%20%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%81%8B%E3%82%89%20rps%20%E3%82%92%200%20%E3%81%AB%E8%A8%AD%E5%AE%9A%3CBR%20%2F%3E%5B%2017.617918%5D%20SDIW612%3A%20usr%20cfg%20%E3%81%8B%E3%82%89%E3%81%AE%20init%20%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%3CBR%20%2F%3E%5B%2017.623162%5D%20card_type%3A%20SDIW612%E3%80%81%E6%A7%8B%E6%88%90%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%3A%200%3CBR%20%2F%3E%5B%2017.627774%5D%20cfg80211_wext%3D0xf%3CBR%20%2F%3E%5B%2017.630789%5D%20max_vir_bss%3D1%3CBR%20%2F%3E%5B%2017.633448%5D%20cal_data_cfg%3D%E3%81%AA%E3%81%97%3CBR%20%2F%3E%5B%2017.636416%5D%20ps_mode%20%3D%201%3CBR%20%2F%3E%5B%2017.641499%5D%20auto_ds%20%3D%201%3CBR%20%2F%3E%5B%2017.643983%5D%20host_mlme%3D%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%3CBR%20%2F%3E%5B%2017.649504%5D%20fw_name%3Dnxp%2Fsduart_nw61x_v1.bin.se%3CBR%20%2F%3E%5B%2017.654084%5D%20txpwrlimit_cfg%3DNXP%2Ftxpower_QSM_US.bin%3CBR%20%2F%3E%5B%2017.658916%5D%20SDIO%3A%20max_segs%3D128%20max_seg_size%3D65535%3CBR%20%2F%3E%5B%2017.663765%5D%20rx_work%3D1%20cpu_num%3D2%3CBR%20%2F%3E%5B%2017.666995%5D%20moal_recv_amsdu_packet%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%3CBR%20%2F%3E%5B%2017.671074%5D%20mlan%E3%82%A2%E3%83%80%E3%83%97%E3%82%BFoperations.card_type%E3%82%92%E5%8F%96%E3%82%8A%E4%BB%98%E3%81%910x109%E3%80%82%3CBR%20%2F%3E%5B%2017.682854%5D%20wlan%3ATX%20SG%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%3CBR%20%2F%3E%5B%2017.686391%5D%20wlan%3ARX%20SG%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%3CBR%20%2F%3E%5B%2017.693610%5D%20%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E3%83%AA%E3%82%AF%E3%82%A8%E3%82%B9%E3%83%88%3A%20nxp%2Fsduart_nw61x_v1.bin.se%3CBR%20%2F%3E%5B%2018.046530%5D%20Wlan%3A%20FW%20%E3%81%AE%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E7%B5%82%E4%BA%86%E3%80%81firmwarelen%3D1004248%20%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E6%B8%88%E3%81%BF%20916048%3CBR%20%2F%3E%5B%2018.453634%5D%20WLAN%20FW%20%E3%81%8C%E3%82%A2%E3%82%AF%E3%83%86%E3%82%A3%E3%83%96%E3%81%A7%E3%81%99%3CBR%20%2F%3E%5B%2018.456624%5D%20on_time%2018307253173%3CBR%20%2F%3E%5B%2018.460061%5D%20%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%20txpwrlimit_cfg%3Dnxp%2Ftxpower_US.bin%3CBR%20%2F%3E%5B%2018.487779%5D%20VDLL%E7%94%BB%E5%83%8F%3Alen%3D88200%3CBR%20%2F%3E%5B%2018.519055%5D%20fw_cap_info%3D0x487cff03%E3%80%81dev_cap_mask%3D0xffffffff%3CBR%20%2F%3E%5B%2018.524681%5D%20UUID%3A%20521D887A0A925DA4A1Fe6A6F39966212%3CBR%20%2F%3E%5B%2018.529497%5D%20max_p2p_conn%20%3D%208%E3%80%81max_sta_conn%20%3D%2016%3CBR%20%2F%3E%5B%2018.559956%5D%20NXP%20802.11%E3%82%A2%E3%83%80%E3%83%97%E3%82%BFmlan0%E3%82%92%E7%99%BB%E9%8C%B2%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3E%5B%2018.566109%5D%20WLAN%3A%20UAP%25D%20max_mtu%202000%20%E3%81%AB%E8%A8%AD%E5%AE%9A%3CBR%20%2F%3E%5B%2018.574646%5D%20NXP%20802.11%E3%82%A2%E3%83%80%E3%83%97%E3%82%BFuap0%E3%82%92%E7%99%BB%E9%8C%B2%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3E%5B%2018.608521%5D%20NXP%20802.11%E3%82%A2%E3%83%80%E3%83%97%E3%82%BFwfd0%E3%82%92%E7%99%BB%E9%8C%B2%3CBR%20%2F%3E%5B%2018.619407%5D%20WLAN%3A%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%3D%20SDIW612---18.99.2.p66.17-MM6X18437.p3-GPL-(FP92)%3CBR%20%2F%3E%5B%2018.636305%5D%20wlan%3A%E3%83%90%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%B8%E3%81%AE%E7%99%BB%E9%8C%B2%E5%AE%8C%E4%BA%86%3CBR%20%2F%3E%5B%2018.645522%5D%20wlan%3A%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%81%8C%E6%AD%A3%E5%B8%B8%E3%81%AB%E3%83%AD%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%5B%2021.266693%5D%20%3CSTRONG%3E%3CFONT%20color%3D%22%23FF0000%22%3EFW%E3%83%88%E3%83%AA%E3%82%AC%E3%83%BCFW%E3%83%80%E3%83%B3%E3%83%97%3C%2FFONT%3E%3C%2FSTRONG%3E%3CBR%20%2F%3E%5B%2021.269817%5D%20%3D%3D%3D%3D%3DFW%E3%83%88%E3%83%AA%E3%82%AC%E3%83%BC%E3%83%80%E3%83%B3%E3%83%97%3D%3D%3D%3D%3CBR%20%2F%3E%5B%2021.273726%5D%20%3D%3D%3D%3D%20FW%E3%83%80%E3%83%B3%E3%83%97%E3%82%A4%E3%83%99%E3%83%B3%E3%83%88%E3%81%AE%E5%8F%97%E4%BF%A1%E9%96%8B%E5%A7%8B%20%3D%3D%3D%3D%3CBR%20%2F%3E%5B%2021.278586%5D%20%3D%3D%3D%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E6%83%85%E5%A0%B1%E3%83%80%E3%83%B3%E3%83%97%E3%81%AE%E9%96%8B%E5%A7%8B%3D%3D%3D%3CBR%20%2F%3E%5B%2021.278825%5D%20%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%20%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AE%20FW%20(0xe3)%3CBR%20%2F%3E%5B%2021.394221%5D%20Drv%20%E6%83%85%E5%A0%B1%E5%90%88%E8%A8%88%E3%83%90%E3%82%A4%E3%83%88%E6%95%B0%20%3D%20336781%20(0x5238d)%3CBR%20%2F%3E%5B%2021.399129%5D%20%3D%3D%3D%20%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E6%83%85%E5%A0%B1%E3%83%80%E3%83%B3%E3%83%97%20END%3D%3D%3D%3CBR%20%2F%3E%5B%2022.215633%5D%20%3D%3D%3D%3D%20FW%E3%83%80%E3%83%B3%E3%83%97%E7%B5%82%E4%BA%86%3A1336880%E3%83%90%E3%82%A4%E3%83%88%3D%3D%3D%3D%3CBR%20%2F%3E%5B%2022.224118%5D%20FW%E3%83%80%E3%83%B3%E3%83%97%E5%85%A8%E9%95%B7%E3%81%AF1336892%3CBR%20%2F%3E%5B%2022.228385%5D%20%E3%83%8F%E3%83%B3%E3%82%B0%E3%81%AE%E5%87%A6%E7%90%86%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3E%5B%2022.232045%5D%20%E4%BF%9D%E7%95%99%E4%B8%AD%E3%81%AE%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%20cmd%20%E3%81%8A%E3%82%88%E3%81%B3%20txrx%20%E3%82%AD%E3%83%A5%E3%83%BC%E3%82%92%E3%82%AD%E3%83%A3%E3%83%B3%E3%82%BB%E3%83%AB%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3E%5B%2022.236901%5D%20WIFI%20auto_fw_reload%3Afw_reload%20%3D%201%3CBR%20%2F%3E%5B%2022.241239%5D%20%3D%3D%3D%3D%3D%3D%3D%3D%E3%82%A4%E3%83%B3%E3%83%90%E3%83%B3%E3%83%89%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%82%92%E9%96%8B%E5%A7%8B%E3%81%97%E3%81%BE%E3%81%99%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3CBR%20%2F%3E%5B%2022.246180%5D%20woal_reset_intf%3A%20BSS%20%E6%83%85%E5%A0%B1%E3%81%AE%E5%8F%96%E5%BE%97%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%5B%2022.250927%5D%20%E4%BF%9D%E7%95%99%E4%B8%AD%E3%81%AE%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%20cmd%20%E3%81%8A%E3%82%88%E3%81%B3%20txrx%20%E3%82%AD%E3%83%A5%E3%83%BC%E3%82%92%E3%82%AD%E3%83%A3%E3%83%B3%E3%82%BB%E3%83%AB%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3E%5B%2022.390250%5D%20woal_close%3A%20woal_disconnect%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%5B%2022.662577%5D%20FW%E3%82%A6%E3%82%A7%E3%82%A4%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%3CBR%20%2F%3E%5B%2022.666271%5D%20SDIO%20%E3%83%88%E3%83%AA%E3%82%AC%E3%83%BC%20FW%20%E3%82%A4%E3%83%B3%E3%83%90%E3%83%B3%E3%83%89%20%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E6%88%90%E5%8A%9F%3CBR%20%2F%3E%5B%2022.666304%5D%20SDIO%3Amax_segs%3D128%20max_seg_size%3D65535%3CBR%20%2F%3E%5B%2022.677190%5D%20rx_work%3D1%20cpu_num%3D2%3CBR%20%2F%3E%5B%2022.681162%5D%20moal_recv_amsdu_packet%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%3CBR%20%2F%3E%5B%2022.686153%5D%20mlan%E3%82%A2%E3%83%80%E3%83%97%E3%82%BFoperations.card_type%E3%82%92%E3%82%A2%E3%82%BF%E3%83%83%E3%83%810x109%E3%80%82%3CBR%20%2F%3E%5B%2022.693545%5D%20wlan%3ATX%20SG%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%3CBR%20%2F%3E%5B%2022.697059%5D%20wlan%3ARX%20SG%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%3CBR%20%2F%3E%5B%2022.701957%5D%20%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E3%83%AA%E3%82%AF%E3%82%A8%E3%82%B9%E3%83%88%3Anxp%2Fsduart_nw61x_v1.bin.se%3CBR%20%2F%3E%5B%2023.067701%5D%20Wlan%3A%20FW%20%E3%81%AE%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E7%B5%82%E4%BA%86%E3%80%81firmwarelen%3D1004248%20%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E6%B8%88%E3%81%BF%20916048%3CBR%20%2F%3E%5B%2029.077402%5D%20%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%B9%E3%83%86%E3%83%BC%E3%82%BF%E3%82%B9%E3%81%AE%E3%83%9D%E3%83%BC%E3%83%AA%E3%83%B3%E3%82%B0%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3A%20firmwarestat%3D0x0%3CBR%20%2F%3E%5B%2029.082928%5D%20FW%E3%81%8C%E6%99%82%E9%96%93%E5%86%85%E3%81%AB%E3%82%A2%E3%82%AF%E3%83%86%E3%82%A3%E3%83%96%E3%81%AB%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F!%3CBR%20%2F%3E%5B%2029.087135%5D%20wlan_dnld_fw%E5%A4%B1%E6%95%97ret%3D0xffffffff%3CBR%20%2F%3E%5B%2029.091440%5D%20%3CFONT%20color%3D%22%23FF0000%22%3E%3CSTRONG%3EWLAN%3Anowwait%E3%81%A7FW%E3%81%AE%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3A0%3C%2FSTRONG%3E%3C%2FFONT%3E%3CBR%20%2F%3E%5B%2029.096577%5D%20SDIO%20Func0%20(0x0-0x9)%3A%2043%2003%2002%2002%2003%2000%2000%2002%2003%2000%2002%2003%2000%3CBR%20%2F%3E%5B%2029.103437%5D%20SDIO%20Func1%20(0x10-0x17)%3A%2000%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%5B%2029.109526%5D%20SDIO%20Func1%3A%20(0x8)%2000%20(0x58)%2000%20(0x5c)%200d%20(0x5d)%2000%20(0x60)%2001%20(0x61)%2000%20(0x62)%2000%20(0x64)%2010%20(0x65)%2000%20(0x66)%2000%20(0x68)%2000%20(0x69)%2000%20(0x6a)%2000%3CBR%20%2F%3E%5B%2029.123829%5D%20SDIO%20Func1%20(0xe8-0xff)%3A%2000%2000%2000%2000%2050%20fa%200d%2000%2024%2014%2070%20c8%20ab%2037%2080%2000%2000%2000%2000%2000%2001%2000%2000%2000%2000%3CBR%20%2F%3E%5B%2029.235469%5D%20SDIO%20Func1%20(0xe8-0xff)%3A%2000%2000%2000%2000%2050%20fa%200d%2000%2024%2014%2070%20c8%20ab%2037%2080%2000%2000%2000%2000%2000%2001%2000%2000%2000%2000%3CBR%20%2F%3E%5B%2029.245502%5D%20woal_request_fw%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%5B%2029.248901%5D%20%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%5B%2029.252479%5D%20SDIO%20Func0%20(0x0-0x9)%3A%2043%2003%2002%2002%2003%2000%2000%2002%2003%2000%2002%2003%2000%3CBR%20%2F%3E%5B%2029.258736%5D%20SDIO%20Func1%20(0x10-0x17)%3A%2000%2000%2000%2000%2000%2000%2000%2000%2000%3CBR%20%2F%3E%5B%2029.264745%5D%20SDIO%20Func1%3A%20(0x8)%2000%20(0x58)%2000%20(0x5c)%200d%20(0x5d)%2000%20(0x60)%2001%20(0x61)%2000%20(0x62)%2000%20(0x64)%2010%20(0x65)%2000%20(0x66)%2000%20(0x68)%2000%20(0x69)%2000%20(0x6a)%2000%3CBR%20%2F%3E%5B%2029.279066%5D%20SDIO%20Func1%20(0xe8-0xff)%3A%2000%2000%2000%2000%2050%20fa%200d%2000%2024%2014%2070%20c8%20ab%2037%2080%2000%2000%2000%2000%2000%2001%2000%2000%2000%2000%3CBR%20%2F%3E%5B%2029.389834%5D%20SDIO%20Func1%20(0xe8-0xff)%3A%2000%2000%2000%2000%2050%20fa%200d%2000%2024%2014%2070%20c8%20ab%2037%2080%2000%2000%2000%2000%2000%2001%2000%2000%2000%2000%3CBR%20%2F%3E%5B%2029.489860%5D%20%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%81%AE%E8%87%AA%E7%94%B1%E5%8C%96%3CBR%20%2F%3E%5B%2029.492947%5D%20%3D%3D%3D%3D%3D%3D%3D%3D%E3%82%A4%E3%83%B3%E3%83%90%E3%83%B3%E3%83%89%20%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%81%AE%E7%B5%82%E4%BA%86%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1890021%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EOS%20LINUX%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3E%E8%A3%BD%E5%93%81%3A%20WiFi%20IW6XX%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3E%E3%83%97%E3%83%AD%E3%83%88%E3%82%B3%E3%83%AB%EF%BC%9AWi-Fi%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1902221%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20L6.6.3%20iw612%20load%20txpower_cfg%20fail%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1902221%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F186613%22%20target%3D%22_blank%22%3E%40shaun_wu%3C%2FA%3E%26nbsp%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%E3%81%8A%E3%81%8B%E3%81%92%E3%81%A7%E3%80%81FW%E3%81%A8%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%82%926.6.23%E3%81%AB%E5%BC%B7%E5%88%B6%E7%9A%84%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%9F%E5%BE%8C%E3%80%81%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%8C%E8%A7%A3%E6%B1%BA%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3Eroot%40quilt-IMX93-QSM%3A~%23%20modprobe%20moal%20mod_para%3Dnxp%2Fwifi_mod_para_qsm.conf%3CBR%20%2F%3E%5B%2022.253697%5D%20MLAN%3A%E3%83%84%E3%83%AA%E3%83%BC%E5%A4%96%E3%81%AE%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89%E3%81%99%E3%82%8B%E3%81%A8%E3%82%AB%E3%83%BC%E3%83%8D%E3%83%AB%E3%81%8C%E6%B1%9A%E6%9F%93%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%5B%2022.317581%5D%20wlan%3AMWLAN%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%AE%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%81%BF%3CBR%20%2F%3E%5B%2022.326493%5D%20wlan%3A%E3%83%90%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%AB%E7%99%BB%E9%8C%B2...%3CBR%20%2F%3E%5B%2022.338429%5D%20%E3%83%99%E3%83%B3%E3%83%80%E3%83%BC%3D0x0471%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%3D0x0205%20class%3D0%20function%3D1%3CBR%20%2F%3E%5B%2022.344079%5D%20%E3%83%A2%E3%83%BC%E3%83%AB%E3%83%8F%E3%83%B3%E3%83%89%E3%83%AB%E3%82%AA%E3%83%97%E3%82%B9%E3%82%92%E5%8F%96%E3%82%8A%E4%BB%98%E3%81%91%E3%80%81%E3%82%AB%E3%83%BC%E3%83%89%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%82%BF%E3%82%A4%E3%83%97%3A0x109%3CBR%20%2F%3E%5B%2022.349968%5D%20%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%20%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%81%8B%E3%82%89%20RPS%20%E3%82%92%200%20%E3%81%AB%E8%A8%AD%E5%AE%9A%3CBR%20%2F%3E%5B%2022.355413%5D%20SDIW612%3A%20usr%20cfg%20%E3%81%8B%E3%82%89%E3%81%AE%20init%20%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%20%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%3CBR%20%2F%3E%5B%2022.360371%5D%20card_type%3A%20SDIW612%E3%80%81%E6%A7%8B%E6%88%90%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%3A%200%3CBR%20%2F%3E%5B%2022.364935%5D%20cfg80211_wext%3D0xf%3CBR%20%2F%3E%5B%2022.367927%5D%20max_vir_bss%3D1%3CBR%20%2F%3E%5B%2022.370569%5D%20cal_data_cfg%3D%E3%81%AA%E3%81%97%3CBR%20%2F%3E%5B%2022.373554%5D%20ps_mode%20%3D%201%3CBR%20%2F%3E%5B%2022.376013%5D%20auto_ds%20%3D%201%3CBR%20%2F%3E%5B%2022.378482%5D%20host_mlme%3D%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%3CBR%20%2F%3E%5B%2022.381390%5D%20fw_name%3DNXP%2Fsduart_nw61x_v1.bin.se%3CBR%20%2F%3E%5B%2022.385857%5D%20txpwrlimit_cfg%3DNXP%2Ftxpower_US.bin%3CBR%20%2F%3E%5B%2022.390616%5D%20SDIO%3Amax_segs%3D128%20max_seg_size%3D65535%3CBR%20%2F%3E%5B%2022.395338%5D%20rx_work%3D1%20cpu_num%3D2%3CBR%20%2F%3E%5B%2022.398522%20%5D%20moal_recv_amsdu_packet%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%3CBR%20%2F%3E%5B%2022.402675%5D%20MLAN%E3%82%A2%E3%83%80%E3%83%97%E3%82%BF%E3%83%BC%20operations.card_type%E3%82%92%E5%8F%96%E3%82%8A%E4%BB%98%E3%81%910x109%E3%80%82%3CBR%20%2F%3E%5B%2022.414743%5D%20wlan%3ATX%20SG%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%3CBR%20%2F%3E%5B%2022.418371%5D%20wlan%3ARX%20SG%E3%83%A2%E3%83%BC%E3%83%89%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%3CBR%20%2F%3E%5B%2022.426370%5D%20%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E8%A6%81%E6%B1%82%3Anxp%2Fsduart_nw61x_v1.bin.se%3CBR%20%2F%3E%5B%2022.778840%5D%20Wlan%3A%20FW%20%E3%81%AE%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E7%B5%82%E4%BA%86%E3%80%81firmwarelen%3D1038668%20%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E6%B8%88%E3%81%BF%20936668%3CBR%20%2F%3E%5B%2023.181312%5D%20WLAN%20FW%20%E3%81%8C%E3%82%A2%E3%82%AF%E3%83%86%E3%82%A3%E3%83%96%E3%81%A7%E3%81%99%3CBR%20%2F%3E%5B%2023.184329%5D%20on_time%E3%81%AF22921111967%3CBR%20%2F%3E%5B%2023.187759%5D%20%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%20txpwrlimit_cfg%3Dnxp%2Ftxpower_US.bin%3CBR%20%2F%3E%5B%2023.221031%5D%20VDLL%E7%94%BB%E5%83%8F%3Alen%3D102000%3CBR%20%2F%3E%5B%2023.265041%5D%20fw_cap_info%3D0x487cff03%E3%80%81dev_cap_mask%3D0xffffffff%3CBR%20%2F%3E%5B%2023.270673%5D%20UUID%3A%20521D887A0A925DA4A1Fe6A6F39966212%3CBR%20%2F%3E%5B%2023.275483%5D%20max_p2p_conn%20%3D%208%E3%80%81max_sta_conn%20%3D%2016%3CBR%20%2F%3E%5B%2023.410178%5D%20NXP%20802.11%E3%82%A2%E3%83%80%E3%83%97%E3%82%BFmlan0%E3%82%92%E7%99%BB%E9%8C%B2%3CBR%20%2F%3E%5B%2023.414909%5D%20WLAN%3A%20UAP%25d%20%E3%82%BB%E3%83%83%E3%83%88%20max_mtu%202000%3CBR%20%2F%3E%5B%2023.424961%5D%20NXP%20802.11%E3%82%A2%E3%83%80%E3%83%97%E3%82%BF%E3%83%BCuap0%E3%82%92%E7%99%BB%E9%8C%B2%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3E%5B%2023.541433%5D%20NXP%20802.11%E3%82%A2%E3%83%80%E3%83%97%E3%82%BFwfd0%E3%82%92%E7%99%BB%E9%8C%B2%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3E%5B%2023.547371%5D%20%3CSTRONG%3E%3CFONT%20color%3D%22%23FF0000%22%3E%E7%84%A1%E7%B7%9ALAN%3A%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%3D%20SDIW612---18.99.3.p10.1-MM6X18437.p21-GPL-(FP92)%3C%2FFONT%3E%3C%2FSTRONG%3E%3CBR%20%2F%3E%5B%2023.584774%5D%20wlan%3A%E3%83%90%E3%82%B9%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%B8%E3%81%AE%E7%99%BB%E9%8C%B2%E5%AE%8C%E4%BA%86%3CBR%20%2F%3E%5B%2023.591295%5D%20wlan%3A%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%E3%83%BC%E3%81%8C%E6%AD%A3%E5%B8%B8%E3%81%AB%E3%83%AD%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1901892%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20L6.6.3%20iw612%20load%20txpower_cfg%20fail%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1901892%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F223693%22%20target%3D%22_blank%22%3E%40Chihyu_Lin%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%A76.6.23%E3%82%92%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%BF%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%3F6.6.23%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%81%A7%E3%82%82%E5%90%8C%E6%A7%98%E3%81%AE%E4%BF%AE%E6%AD%A3%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%3CSPAN%20class%3D%22%22%3E%E3%82%B7%E3%83%A7%E3%83%BC%E3%83%B3%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1895823%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20L6.6.3%20iw612%20load%20txpower_cfg%20fail%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1895823%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F223693%22%20target%3D%22_blank%22%3E%40Chihyu_Lin%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%AF%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E5%95%8F%E9%A1%8C%E3%82%92%E5%86%8D%E7%8F%BE%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%80%81%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%AF%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%82%92%E5%86%85%E9%83%A8%E3%81%A7%E8%BF%BD%E8%B7%A1%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E9%80%B2%E6%8D%97%E7%8A%B6%E6%B3%81%E3%81%8C%E3%82%8F%E3%81%8B%E3%82%8A%E6%AC%A1%E7%AC%AC%E3%80%81%E3%81%8A%E7%9F%A5%E3%82%89%E3%81%9B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E6%84%9F%E8%AC%9D%EF%BC%81%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%82%B7%E3%83%A7%E3%83%BC%E3%83%B3%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1892031%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20L6.6.3%20iw612%20load%20txpower_cfg%20fail%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1892031%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F186613%22%20target%3D%22_blank%22%3E%40shaun_wu%3C%2FA%3E%26nbsp%3B%3CBR%20%2F%3ETx%E9%9B%BB%E6%BA%90%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E6%B7%BB%E4%BB%98%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%81%AF%E3%83%90%E3%82%A4%E3%83%8A%E3%83%AA%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AE%E3%82%A2%E3%83%83%E3%83%97%E3%83%AD%E3%83%BC%E3%83%89%E3%82%92%E8%A8%B1%E5%8F%AF%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1891972%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20L6.6.3%20iw612%20load%20txpower_cfg%20fail%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1891972%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F223693%22%20target%3D%22_blank%22%3E%40Chihyu_Lin%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%8C%E4%BD%BF%E3%81%A3%E3%81%9Ftxpower_US.bin%E3%82%92%E6%95%99%E3%81%88%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%3E%E6%9C%80%E9%AB%98%E3%81%AERergards%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E3%82%B7%E3%83%A7%E3%83%BC%E3%83%B3%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1890260%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20L6.6.3%20iw612%20load%20txpower_cfg%20fail%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1890260%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Ewifi_mod_para.conf%E3%81%A7tx%E9%9B%BB%E5%8A%9B%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%A7%E3%81%8D%E3%82%8B%E5%A0%B4%E6%89%80%E3%81%AF1%E3%81%A4%E3%81%A0%E3%81%91%E3%81%A7%E3%80%81L6.1.55%E3%81%A7nxp-wlan-sdk%E3%82%92%E3%82%A2%E3%83%83%E3%83%97%E3%82%B0%E3%83%AC%E3%83%BC%E3%83%89%E3%81%97%E3%81%BE%E3%81%99%E5%90%8C%E3%81%98%E5%88%9D%E6%9C%9F%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%A8%E5%95%8F%E9%A1%8C%E3%81%AA%E3%81%8Ftxpower_US.bin%E3%80%82%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1890242%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20L6.6.3%20iw612%20load%20txpower_cfg%20fail%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1890242%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E3%81%AF%20i.MX%209302A1%20imx-6.6.3-1.0.0%20%E3%83%99%E3%83%BC%E3%82%B9%3CBR%20%2F%3ENXP-wlan-sdk%20SRCREV%3D%3Aa84df583155bad2a396a937056805550bdf655ab%22%3CBR%20%2F%3EWLAN%3A%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%3D%20SDIW612---18.99.2.P66.17-MM6X18423.P6-GPL-(FP92)%3CBR%20%2F%3E%E3%81%9D%E3%81%97%E3%81%A6%E3%80%81wifi_mod_para.conf%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%81%A7%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3ESDIW612%20%3D%20%7B%3CBR%20%2F%3Ecfg80211_wext%3D0xf%3CBR%20%2F%3Emax_vir_bss%3D1%3CBR%20%2F%3Ecal_data_cfg%3D%E3%81%AA%E3%81%97%3CBR%20%2F%3Eps_mode%3D1%3CBR%20%2F%3Eauto_ds%3D1%3CBR%20%2F%3Ehost_mlme%3D1%3CBR%20%2F%3Efw_name%3Dnxp%2Fsduart_nw61x_v1.bin.se%3CBR%20%2F%3Etxpwrlimit_cfg%3DNXP%2Ftxpower_US.bin%3CBR%20%2F%3E%7D%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1890223%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20L6.6.3%20iw612%20load%20txpower_cfg%20fail%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1890223%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F223693%22%20target%3D%22_blank%22%3E%40Chihyu_Lin%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E5%95%8F%E9%A1%8C%E3%81%AF%E3%80%81%E8%A8%AD%E5%AE%9A%E3%81%8C%E3%81%99%E3%81%A7%E3%81%AB%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8Btx_pwr%E3%80%81%E5%86%8D%E5%BA%A6%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%99%E3%82%8B%E3%81%A8%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E5%A0%B1%E5%91%8A%E3%81%95%E3%82%8C%E3%81%9F%E3%81%93%E3%81%A8%E3%81%A7%E3%81%82%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%E9%9B%BB%E6%BA%90%E3%82%92%E5%88%87%E3%81%A3%E3%81%A6%E3%81%8B%E3%82%89%E3%80%81%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E3%82%92%E5%86%8D%E8%B5%B7%E5%8B%95%E3%81%97%E3%81%A6%E3%81%BF%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%82%B7%E3%83%A7%E3%83%BC%E3%83%B3%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1890211%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20L6.6.3%20iw612%20load%20txpower_cfg%20fail%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1890211%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F223693%22%20target%3D%22_blank%22%3E%40Chihyu_Lin%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%83%AC%E3%83%9D%E3%83%BC%E3%83%88%E3%82%92%E5%8F%96%E5%BE%97%E3%81%99%E3%82%8B%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%82%92%E3%81%8A%E7%9F%A5%E3%82%89%E3%81%9B%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%82%B7%E3%83%A7%E3%83%BC%E3%83%B3%3C%2FP%3E%3C%2FLINGO-BODY%3E
