If its normal behavior 88W8997 2.4G STA bgn mode can only get ~150 Mbps THP in shielding room.
yao_feng
platform (Host CPU): i.mx8mm
OS: Linux 5.15.71_2.2.1
HW: i.mx8mm customer board + WiFi module:
AW-CM276MA-PUR (M.2)
BSP version: Linux 5.15.71_2.2.1
Driver version and Wi-Fi and Bluetooth/Bluetooth LE Firmware version: PCIE8997--16.92.21.p55.3-MM5X16366.p5-GPL-(FP92)
AP: ASUS and MSI AP Router
in Shielding room
Customer test 2.4G bgn mode 40MHz THP iperf test.
Test 1: Default settings, only can get ~150Mbps
Test 2: if set script before iperf test
mlanutl mlan0 httxcfg 0x07F
mlanutl mlan0 htcapinfo 0x21C20000
THP can reach ~240Mbps
-> Customer has questions on Test 1. if its normal behavior?
Note: there is no STA bgn mode 40MHz speed result reference data in RN.
@Christine_Li  Please help to clarify.
Christine_Li
Hi, @yao_feng
Please see your email, I have sent my reply through SFDC's email.
Christine.
Christine_Li
Hi, @yao_feng
I will check it and reply you ASAP.
Christine.
Christine_Li
Hi, @yao_feng
Christine.
%3CLINGO-SUB%20id%3D%22lingo-sub-1927113%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EIf%20its%20normal%20behavior%2088W8997%202.4G%20STA%20bgn%20mode%20can%20only%20get%20~150%20Mbps%20THP%20in%20shielding%20room.%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1927113%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3Eplatform%20(Host%20CPU)%3A%20i.mx8mm%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3EOS%3A%20Linux%205.15.71_2.2.1%3CBR%20%2F%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3EHW%3A%20i.mx8mm%20customer%20board%20%2B%20WiFi%20module%3A%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3EAW-CM276MA-PUR%20(M.2)%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%3EBSP%20version%3A%20Linux%205.15.71_2.2.1%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3EDriver%20version%20and%20Wi-Fi%20and%20Bluetooth%2FBluetooth%20LE%20Firmware%20version%3A%20PCIE8997--16.92.21.p55.3-MM5X16366.p5-GPL-(FP92)%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EAP%3A%20ASUS%20and%20MSI%20AP%20Router%3CBR%20%2F%3Ein%20Shielding%20room%3C%2FP%3E%3CP%3ECustomer%20test%202.4G%20bgn%20mode%2040MHz%20THP%20iperf%20test.%3CBR%20%2F%3ETest%201%3A%20Default%20settings%2C%20only%20can%20get%20~150Mbps%3CBR%20%2F%3ETest%202%3A%20if%20set%20script%20before%20iperf%20test%3CBR%20%2F%3Emlanutl%20mlan0%20httxcfg%200x07F%3CBR%20%2F%3Emlanutl%20mlan0%20htcapinfo%200x21C20000%3CBR%20%2F%3ETHP%20can%20reach%20~240Mbps%3CBR%20%2F%3E%3CBR%20%2F%3E-%26gt%3B%20Customer%20has%20questions%20on%20Test%201.%20if%20its%20normal%20behavior%3F%3CBR%20%2F%3E%3CBR%20%2F%3ENote%3A%20there%20is%20no%20STA%20bgn%20mode%2040MHz%20speed%20result%20reference%20data%20in%20RN.%3CBR%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F205377%22%20target%3D%22_blank%22%3E%40Christine_Li%3C%2FA%3E%26nbsp%3B%20Please%20help%20to%20clarify.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1928005%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20If%20its%20normal%20behavior%2088W8997%202.4G%20STA%20bgn%20mode%20can%20only%20get%20~150%20Mbps%20THP%20in%20shielding%20room.%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1928005%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F144174%22%20target%3D%22_blank%22%3E%40yao_feng%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EPlease%20see%20your%20email%2C%20I%20have%20sent%20my%20reply%20through%20SFDC's%20email.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBest%20regards%2C%3C%2FP%3E%0A%3CP%3EChristine.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1927303%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20If%20its%20normal%20behavior%2088W8997%202.4G%20STA%20bgn%20mode%20can%20only%20get%20~150%20Mbps%20THP%20in%20shielding%20room.%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1927303%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%EF%BC%8C%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F144174%22%20target%3D%22_blank%22%3E%40yao_feng%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EI%20will%20check%20it%20and%20reply%20you%20ASAP.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBest%20regards%2C%3C%2FP%3E%0A%3CP%3EChristine.%3C%2FP%3E%3C%2FLINGO-BODY%3E
