How to disable 5GHz on verdin8mm (AWCM276NF)
Rabeb
I want to disable 5Ghz on verdin8mm module wchich utilize an AzureWave AW-CM276NF wireless module, have you any idea how to do that please ?
Rabeb
Unfortunately, the solution was not successful. I have developed a patch to deactivate the 5G WiFi feature from the driver.
DanielRuvalcaba
Could you please confirm you are using i.MX8MM as the host for AW-CM276NF. These two devices are embedded in one SoM. Am I correct?
What OS version are you using?
Daniel.
Rabeb
Hi @DanielRuvalcaba , yes i m using verdin imx8 mini. It flashed with embedded linux kernel 5.4.91-5.2.0-devel
DanielRuvalcaba
Please try to add in your wifi_mod_para.conf this parameter dev_cap_mask=0xffffdbff.
I would also recommend you take a look at this thread.
Daniel.
Rabeb
%3CLINGO-SUB%20id%3D%22lingo-sub-1897350%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EHow%20to%20disable%205GHz%20on%20verdin8mm%20(AWCM276NF)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1897350%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20want%20to%20disable%205Ghz%20on%20verdin8mm%20module%20wchich%20utilize%20an%20AzureWave%20AW-CM276NF%20wireless%20module%2C%20have%20you%20any%20idea%20how%20to%20do%20that%20please%20%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1904188%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20How%20to%20disable%205GHz%20on%20verdin8mm%20(AWCM276NF)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1904188%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3EUnfortunately%2C%20the%20solution%20was%20not%20successful.%20I%20have%20developed%20a%20patch%20to%20deactivate%20the%205G%20WiFi%20feature%20from%20the%20driver.%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1898730%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20How%20to%20disable%205GHz%20on%20verdin8mm%20(AWCM276NF)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1898730%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3CBR%20%2F%3E%3CBR%20%2F%3EPlease%20try%20to%20add%20in%20your%20wifi_mod_para.conf%20this%20parameter%26nbsp%3B%3CEM%3E%3CSTRONG%3Edev_cap_mask%3D0xffffdbff%3C%2FSTRONG%3E%3C%2FEM%3E%3CEM%3E.%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FEM%3EI%20would%20also%20recommend%20you%20take%20a%20look%20at%20this%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FWireless-Connectivity%2FHow-to-disable-5G-capability-when-using-IW416-module%2Fm-p%2F1848896%22%20target%3D%22_blank%22%3Ethread%3C%2FA%3E.%3CBR%20%2F%3E%3CBR%20%2F%3ERegards%2C%3C%2FP%3E%0A%3CP%3EDaniel.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1897768%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20How%20to%20disable%205GHz%20on%20verdin8mm%20(AWCM276NF)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1897768%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F198556%22%20target%3D%22_blank%22%3E%40DanielRuvalcaba%3C%2FA%3E%26nbsp%3B%2C%20yes%20i%20m%20using%20verdin%20imx8%20mini.%20It%20flashed%20with%20embedded%20linux%20kernel%205.4.91-5.2.0-devel%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1897751%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20How%20to%20disable%205GHz%20on%20verdin8mm%20(AWCM276NF)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1897751%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3CBR%20%2F%3E%3CBR%20%2F%3ECould%20you%20please%20confirm%20you%20are%20using%20i.MX8MM%20as%20the%20host%20for%20AW-CM276NF.%20These%20two%20devices%20are%20embedded%20in%20one%20SoM.%20Am%20I%20correct%3F%3CBR%20%2F%3E%3CBR%20%2F%3EWhat%20OS%20version%20are%20you%20using%3F%3CBR%20%2F%3E%3CBR%20%2F%3ERegards%2C%3C%2FP%3E%0A%3CP%3EDaniel.%3C%2FP%3E%3C%2FLINGO-BODY%3E
