How to disable 5GHz on verdin8mm (AWCM276NF)
1,355 次查看
Rabeb
I want to disable 5Ghz on verdin8mm module wchich utilize an AzureWave AW-CM276NF wireless module, have you any idea how to do that please ?
1,210 次查看
Rabeb
Unfortunately, the solution was not successful. I have developed a patch to deactivate the 5G WiFi feature from the driver.
4 回复数
1,332 次查看
DanielRuvalcaba
Could you please confirm you are using i.MX8MM as the host for AW-CM276NF. These two devices are embedded in one SoM. Am I correct?
What OS version are you using?
Daniel.
1,324 次查看
Rabeb
Hi @DanielRuvalcaba , yes i m using verdin imx8 mini. It flashed with embedded linux kernel 5.4.91-5.2.0-devel
1,292 次查看
DanielRuvalcaba
Please try to add in your wifi_mod_para.conf this parameter dev_cap_mask=0xffffdbff.
I would also recommend you take a look at this thread.
Daniel.
1,211 次查看
Rabeb
